Page 5 of 5 FirstFirst ... 345
Results 61 to 67 of 67
Thread: DIY: Shiver Valve Check, Illustrated
  1. #61
    apriliaforum expert Mardoch's Avatar
    Jun 2011
    Baton Rouge, LA, USA
    No problem.
    2011 Dorsoduro 750 - Black
    "I contend that we are both atheists. I just believe in one fewer gods than you do. When you understand why you dismiss all the other possible gods, you will understand why I dismiss yours.” - Stephen F. Roberts
  2. #62
    apriliaforum Junkie rocketnz's Avatar
    Jun 2011
    Bondi Beach
    interesting wondered how this worked
  3. #63
    apriliaforum Junkie BitSar's Avatar
    May 2012
    Melbourne, Australia
    I just found this post...
    @ OP - excellent information....thank you
    BLOG = http://bitsar.blogspot.com.au
    Life
    is Complex
    :: {It has an (i)maginary component && a (R)eal component}
  4. #64
    Mar 2011
    Connecticut - US
    Sorry to bump this, but I'm in the middle of valve clearance check and looking for some clarification. When checking the clearances, does the cylinder have to be at top dead center, or just at any point where the cam is not pressing down on the valve? I Got everything apart and measured just the rear cylinder exhaust valves and they are way off, so i think I'm doing something wrong.
    The engine was not at TDC but cam is off the valve, and they were reading between .05 and .10mm (should be .16-.23). I'll try again tonight at TDC but looking for some clarification in the meantime. For those of you that did have to adjust, how far off were they?
  5. #65
    apriliaforum Member JetdocX's Avatar
    Apr 2009
    San Ramon, CA
    Measure the clearance when the lobes are facing 180 degrees away from the buckets. That's cam lobe up. Also double check your math unless you are using metric feeler gages. Measure twice. Saves rework later.
    Mine has not needed shimming. Checked twice in the last 24,000 miles.
    From parts unknown.
  6. #66
    Jan 2012
    NH, USA
    Sorry, a couple dumb questions.
    Quote Originally Posted by petemoss View Post
    ... You want the cams to wind up in the position shown below - note the cam lobe pointed away from the top of the valve (yellow circle). There is a second cam under the cover that can be checked through the window (yellow arrow).
    The cams shown with yelow circle and arrow in the rear cylinder picture above - are they both intake? Are they the right intake and left intake respectively (i.e. yellow circle is right and yellow arrow is left)?
    Are the red circle & arrow I added to Pete's picture, as shown below, both exhaust cams (right & left respectively)?
    Should both the Intake (left & right) be checked to be within specs? Intake: 0.11 - 0.18 mm (0.0043 - 0.0071 in).
    And both the exhaust be checked? Exhaust: 0.16 - 0.23 mm (0.0063 - 0.0091 in)
    And, for the front cylinder picture below (my edit of Pete's original), pretty much the same thing?
    Yellow Circle -> Right intake; Yellow arrow -> Left intake. Spec: 0.11 - 0.18 mm (0.0043 - 0.0071 in)
    Red Circle -> Right Exhaust; Red arrow -> Left exhaust. Spec: 0.16 - 0.23 mm (0.0063 - 0.0091 in)
    Thanks!
  7. #67
    apriliaforum newb Dierick's Avatar
    Apr 2012
    Belgium
    @venk25,
    the side of the outlet is the also the side of the outlet of the valves.
    Aprilia SL Shiver 750 / Alfa Romeo 147 1.9JTD 8v Squadra
