Results 31 to 45 of 69
Thread: DIY: Shiver Valve Check, Illustrated
  1. #31
    apriliaforum expert bonehead's Avatar
    Oct 2008
    in a cave in Australia
    How?
    Just cutting?
    It is no measure of health to be well adjusted to a profoundly sick society.
    J. Krishnamurti
    Zeitgeist
    Never confuse who you are with what you do.
    Makka
  2. #32
    Roma, Caput Mundi
    just pull it out from the airbox:
  3. #33
    Mar 2009
    Nimbin, Oztralia
    Presumably removal of the snorkel this will make the engine run even leaner?
  4. #34
    Oct 2008
    Hence........ Memjet.
    Thanks Gabro.
    Will give it a try as part of the Memjet experiments.
    J. Krishnamurti
    Zeitgeist
    Makka
  5. #35
    Mar 2009
    Nimbin, Oztralia
    Mate there are a lot of people hanging on your memjet experimentation.
  6. #36
    Oct 2008
    I can't stand the pressure.
    J. Krishnamurti
    Zeitgeist
    Makka
  7. #37
    apriliaforum expert maxpower220's Avatar
    Sep 2005
    Tampa
    Quote Originally Posted by shekel View Post
    Has anyone actually gotten the A/F ratio on a dyno? Everyone continues to say the bike is running lean, but how do you know. A closed loop Lamba FI system "should" compensate for most anything. I understand the the FI system from the factory is set lean to meet emission standards, but exhaust and intake changes would be compensated for by the FI to remain at the stock level. A new air filter and exhaust doesn't allow that much more air through the motor.
    Any documentation would help me "believe".
    06 GSXR 750
    Previous:
    2009 SMV750
    2006 Ducati 749
    07 SXV5.5
    05 DRZ400SM
    04 RSVR
    94 Honda ST100
    03 SV650 Track bike
    01 Mille
    00 GSXR750
  8. #38
    apriliaforum Member Guyf's Avatar
    May 2009
    Quebec City
    Quote Originally Posted by maxpower220 View Post
    Has anyone actually gotten the A/F ratio on a dyno? Everyone continues to say the bike is running lean, but how do you know. A closed loop Lamba FI system "should" compensate for most anything. I understand the the FI system from the factory is set lean to meet emission standards, but exhaust and intake changes whould be compensated for by the FI to remain at the stock level. A new air filter and exhaust doesn't allow that much more air through the motor.
  9. #39
    Oct 2008
    As I understand it they are not allowed to make maps that break the euro regulations.
    If they do it has lots of red "not to be used on the road" signs on the axone.
    So it will run lean until you fiddle with the injection. Possibly even a bit leaner with pipes and air though possibly not 'cos of the Lambda FI system as you say.
    But as I said, we know how our bikes behave and I've read and heard so many times of exactly these symptoms from running euro reg lean so that is why I spent my dollars on the Memjet.
    Anyway, we'll soon see.
    J. Krishnamurti
    Zeitgeist
    Makka
  10. #40
    May 2009
    Quebec City
    Thanks to the never ending rain we get, (and to petemoss of course) I did the valve check on my Shiver. 4,700 Km. All valves within specs.
    Front cylinder: Exhaust: .208mm - .208mm
    Intake: .110mm - .127mm
    Rear cylinder: Exhaust: .160mm - .160mm
    Intake: .127mm - .127mm
    So most are right on the tight side of the spec. I assume they will loosen up as the engine wear, right?
  11. #41
    Oct 2008
    I believe they tighten.
    J. Krishnamurti
    Zeitgeist
    Makka
  12. #42
    apriliaforum expert CessnaTPA's Avatar
    Jul 2009
    Riverview,Florida
    Quote Originally Posted by Guyf View Post
    Here is a pretty good link about it http://www.dansmc.com/valveclearence.htm
    I just did my own valve check yesterday and one of my intakes was out of adjustment.
    84 Honda XL 100
    87 Suzuki SP 125
    84 Honda XL 200
    89 Honda CR 250
    90 Suzuki DR 350(still own)
    09 Shiver
    10 Ducati Multistrada
  13. #43
    Jul 2009
    Riverview,Florida
    Completed Valve Adjustment
    I just finished adjusting one of my intake valves. Overall it's not that hard to do, I think anyone with average mechanical ability could handle this task.
    I'll post later with some pics on how I did it.
    84 Honda XL 100
    87 Suzuki SP 125
    84 Honda XL 200
    89 Honda CR 250
    09 Shiver
  14. #44
    apriliaforum Member spook's Avatar
    Jul 2009
    Czech Republic
    I know its been a while since this thread was started, but Id like to thank Petemoss for his outstanding guide, helped me with valve check I did today.
    '08 Aprilia Shiver
    '10 Honda CRF250R
  15. #45
    apriliaforum expert marksim's Avatar
    Oct 2008
    Leeds,York.Yorkshire
    Thanks Spook for bringing it to my attention
    CURRENT BIKES
    APRILIA RS 270 MK2 Track Fully sorted Jolly Motos Corsa
    SUZUKI RGV 250 21 Jolly moto street
    KTM SUPERDUKE R Total hooligan
    YAMAHA RD 400F
    KAWASAKI KR1S Special
