Results 1 to 4 of 4
Thread: trouble shooting and maintenance
    apriliaforum expert theknurl's Avatar
    Mar 2007
    Palos Verdes Est. SoCal
    here you go;
    1.>pdf manuals; get them from AF1
    free owners manuals;
    here are Aprilia training manuals, a BIG wiring diagram, graphics, all kinds of good stuff
    2.>Aprilia fault codes; From ignition off, press and hold the LAP/PASS switch on the left handlebar. Turn on the ignition but don't start the bike ( keeping LAP/PASS held ). After 30 seconds or so the temp display on the dash will display error code numbers or 0 if none are displayed. Note that the codes are cleared after this operation.
    3.>the stator test;
    4.>electrical trouble shooting guide;
    5.>finding parasitic battery drains the easy way
    7.>here's a suspension tuning guide;
    8.>for bikes, with hard to find neutral;
    9.>clutch M/C seals;
    10.>replace the click type hose clamps with these All stainless ones;
    11.>fuel cap leak post#9;
    12.>Amauri's temp sensor post #3
    13.>the correct brake and clutch fluid is DOT 4
    14.>bleeding clutch and rear brake by kzmille
    15.>if you lose your key and need to reprogram the Immobilizer;
    16.>list of locksmiths that 'can' cut Aprilia keys
    17.>flywheel removal with pictures (thanks to uberchicken)
    18.>Aprilia bearings and seals
    19.>Clic-R pliers....for all the hose clamps
    20.>the exhaust pipe formula
    21.>manuals for everything thanks to Mille Racer 69;
    It takes a minute for the whole page to load up
    22.>submersible fuel injection line is spec SAE J30R10
    23.> Change Shift Light RPM:
    24.> replacement starter solenoid Yamaha 4KD-81-940-00
    Apr 2006
    in case you're interested in component weights & removing some weight form your bike:
    part weight comparisons - click here:
    2000 Yamaha YZ125
    2002 aprilia Caponord
    2007 aprilia RSVR
    2008 KTM 690 SMC / Enduro R
