Results 1 to 15 of 16
Thread: SR50 Service Manual & Minarelli LC/AC Engine Service Manual
    apriliaforum expert ReplicaOwner's Avatar
    Southeast Indiana USA
    Talking SR50 Service Manual & Minarelli LC/AC Engine Service Manual
    It takes a good repair manual to be able to properly fix these scooters.
    Here are the ones I have found a must have for our model.
    Minarelli Engine Service Manual For AC/LC Engines
    SR50 Service Manual with Minarelli LC/AC engines
    http://www.filedropper.com/apriliasr...anualitaespeng
    Enjoy!
    2000 SR50 Replica #1
    Minarelli 2-Stroke LC
    Martin Racing 72cc Big Bore Kit
    Ceramic Leo Vince ZX Exhaust Pipe
    Gates Powerlink Drive Belt
    4.3 gram Leo Roller Weights
    Yellow Leo Vince Clutch Springs
    Uni-Filter Two-Stage Pod Filter
    Martin Racing Dual Stage Fiber Reeds
    Martin Racing Aluminum Intake, Ported & Polished
    Tireflys Flashing Valve Stem Lights
    Fiber Optic Accent Lights On Belly Pan
    Needle E-Clip on 4th Notch - #115 Jet
    55+ mph on Flat, 62mph in a draft
    Old and New Start Up Video
    Work In Progress...
    apriliaforum expert The_Reaper's Avatar
    Essex, United Kingdom
    thanks rep owner
    2000 SR 50 "Tesuya Harada" Replica
    Finally Sold!!
    2004 RS 125 Tuono
    powervalve fitted and now working
    derestricted cdi
    EBC HH brake pads
    Goodridge braided lines
    Wemoto Shock
    Gianelli Pipe
    Cast iron bore
    Vertex Piston
    Yamaha 350 LC
    project race bike so expect some fancy parts
    Dec 2008
    Scotland
    Rep Owner I just have to say again that site is SH*t for adverts & I still can't download the manual.
    Grrrr!
    Work In Progress...
    Jun 2013
    croatia
    send me your email in a private message and i send you the manual
    Pt
    Bruno.as@vizzavi.pt
    Thanks from Portugal
    GoOdViBeS
    apriliaforum newb SuperBoots's Avatar
    Aug 2015
    Olympia
    Quote Originally Posted by ReplicaOwner View Post
    http://sharebee.com/b6751244
    http://sharebee.com/9a608f44
    or
    http://www.sgnc.dk/00045/
    Enjoy!
    Is there a difference between AC/LC and LC/AC? I'm new to this and I'm looking for the engine repair manual for my 2000 SR50 Minarelli scooter, the normal repair manual I found for it seems to cover everything but the engine.
    Thanks, -Dan
    Jun 2013
    croatia
    LC = liquid cooled
    AC = air cooled
    the cooling system is different, transmission is shorter on the ac model
    but the mechanics are the same and same rules apply
    May 2009
    Hi,
    I am restoring a 1998 SR50LC Harada Replica, I would like some diagrams on engine assembly, it has been over 10 years since I rebuilt the engine and would like a diagram to reference - can anyone help? If so can you please email me at wylieboga@hotmail.com
    Thank you for your help
    Nov 2016
    Aarhus, Denmark
    I just bought a SR 50 year 2000 with Minarelli LC engine. I need to do some service, can anyone help with a service Manual, link above doesn't work. I really appreciate your help and support.
    May 2017
    Germany
    I also bought a SR 50 Ditech from 2001 with Miranelli LC Engine. Due to some service, I would be very pleased if someone could help me by sending the service manual. I already tried the link but it doesn't work anymore.
    It would be great and I would really appreciate your help.
    Jun 2017
    Newport, South Wales
    Hi, I have just bought an SR50 Stealth LC Minarelli. I've managed to get it started but got a seized front wheel, think it's probably the calipers. I'm looking for a service manual which brought me to this forum.
    Can anyone send me one, please?
    Any advice welcome too.
    Many thanks
    ontario
    Quote Originally Posted by zero_G View Post
    Many thanks
    you dont need the manual to find the problem / start a thread and ask for help.
    -remove the caliper and test it. drain it and test its function with compressed air.... just hold the compressor outlet in the calper hole and blast away. start with 25psi and then go up. warning the piston becomes a bullet. put a book or something in the way of it.
    Jun 2017
    Thanks! Will see how I get on this weekend.
