Results 1 to 15 of 25
Thread: sl 1000 falco temp display not working
    apriliaforum prov-nov piro's Avatar
    Apr 2009
    Dubai .United Arab Emirates
    Hi guys , looking to buy a second hand 2004 sl 1000 falco which i've already put down a deposit . My only concern is the right side LCD is not working , ie temp guage , lap timer . Is this a common problem as i'm new to the ape . Any help would be greatly appreciated as i should be picking the bike up in a couple of days .
    Piro
    apriliaforum prov-nov smithrep's Avatar
    Apr 2009
    Charleston, SC
    wish I could help...but I'm a newbie as well. Good luck though, I'm sure its an easy fix and these guys can definitely help you out!
    apriliaforum expert Aladinsaneuk's Avatar
    Nov 2006
    Blighty
    if it is from a stealer, then make them fix it
    if not, then check the prices on evil bay for a replacement unit - be aware that some other aprilia dashes work
    www.ridersite.com - UK home of the Falco Community
    witty banter and sarcasm available for all....
    Jul 2007
    Netherlands
    You can use a RSV250, RSV1000 or Falco dash. You will have a different mileage on your clocks after that so be sure to mark down the original mileage on the replacement clock somewhere.
    Oh and, WAFO!
    apriliaforum expert Katch's Avatar
    circa...Washington D.C.
    Quote Originally Posted by mini_me View Post
    I think mini meant to say "Tuono"
    Steve
    Jan 2009
    Swindon, Wilts
    IF the LCD Panel's gone that side of my original clocks still work, so could have one going for you.
    Upon finding bits left over, refer to the photo you took midway through dismantling for reference.
    Oct 2003
    NUNYA, USA
    I would be suspicious of this bike.
    That is an ODD malody.
    Is the Display out, or just the backlight??? Backlights are EASY (well, sorta) to replace.
    My first impression would be that it was replaced with a unit that didn't work or was crashed....but I AM paranoid!!
    give that bike a GOOD thorough lookin' over before you jump in feet first.
    They CAN be replaced easy, but not necessarily CHEAP.
    gr
    Aug 2005
    Perth W/Australia
    Gday and WAFO !
    Who said you get slower as you get older!
    Jul 2005
    B-More, MD
    Could be something as simple as the PO didn't know what they were doing and pulled the dash apart, and the Ribbon connector off of the LCD screen rather than the circuit board. I accidentally did the same thing with my spare dash while I was working out all the mods before I cracked into my stock one. I don't remember what side I did it to so if it isn't the right side I can send it to you.
    Also have you tried doing a Display Test (Hold A + B and while switching on the Ignition)?
    Bill
    Apr 2009
    Hi njl , the tech at ape reckons that the ribbon that connects the lcd to the circuit board has been shorted , do you still have the clocks available and if so how much do you want , thanks in advance . piro
    Jan 2009
    Swindon, Wilts
    Hi Piro
    My clocks would only be good for parts - last time I had them together the tacho and right side panel were ok, left side lcd is busted, front and back case is damaged. On the PCB there's a small crack in the board that looks to have a track running through it, don't know if it'd cause a problem. If you think you can make up a good set from it I could see how much to send - pm me your location. I'm working away from home for all of June so opportunities to send out will be limited. I wouldn't be after much for the bit's, I have already robbed a couple of backlight bulbs from them!
    Apr 2009
    Hi Njl
    Not sure if the techs need the circuit board or just the ribbon , but its got to be worth a try. I'm actually based in Dubai but have freinds getting married in Cornwall on the 24th of this month and are in the UK now , cheaper to post to them and they can hand carry them back , please advise on how i can get funds to you and what you need . Thanks again for all your help . Piro
    Jul 2007
    Netherlands
    LMAO a Falco in Dubai? I would love some pics! Shall I put you on the falco riders map?
    Apr 2009
    Hi Mini me
    LMAO ? Would love to be put on the map , as far as i know there are only three falcos in the United Arab Emirates and i have the only one in Dubai , pics to follow .
    Jul 2007
    Netherlands
    Quote Originally Posted by piro View Post
    Hi Mini me
    Great! Ive added you m8.
