Results 1 to 15 of 17
Thread: why does my bike keep blowing CDI's?
    apriliaforum expert bourney2007's Avatar
    Jan 2008
    England, Stoke-on-Trent
    probably one for williamr lol
    Well the CDI that came with my bike blew a few weeks ago, thought it was just unlucky, so i bought another, 55!!
    Anyway, 2 days ago that blew aswell. That definitly can't be down to being unlucky, lol.
    So i'm basically thinking of replacing all main electricals components. Bought a regulator/rectifier (it is in one unit williamr, i remember you telling me it was 2 seperate units). Now going to buy a stator and stator plate. Seen one on ebay which comes with a flywheel aswell, he wants 35 + 9 postage. Dosn't sound too bad but he says he's willing to sell the stator and stator plate seperate for 30 posted. So do i need the flywheel?
    When the crank snapped the flywheel obviosly spun around freely inside the generator cover. Hitting the stator. The stator ripped a fair few chunks off the lining inside the flywheel. I just rubbed it smooth. Now have ai done wrong there? would it cause the CDI to blow in any way? do i need a new flywheel?
    cheers.
    Quote Originally Posted by Dom.C View Post
    My Sister's boyfriend is riding it at the moment, his 2 years of restriction is up so it's running 100 brake at the moment.
    hahahahaha dom you fucking legend.
    If you don't get it, read it whilst thinking of nothing but sex
    Jan 2009
    Plymouth, Devon
    I also am having the same problem with my bike. Has gone through 2 CDI's in 3 weeks. I got told it could be a problem with the generator.
    apriliaforum expert Ryan.s's Avatar
    Nov 2008
    Brighton
    u dont really have much luck do u lol ;p
    De-Restricted
    Yellow Rim Tape
    Write off
    Dec 2004
    Cheshire, England
    The 'lining' inside the flywheel contains the magnets that energise the stator. If bits of it are missing you're probably producing uneven surges and eddy currents in the stator. I suppose that could blow the cdi. It needs fixing anyway. If nothing else your flywheel will be out of balance with bits missing.
    I can't be sure of every model of the RS, but all the wiring diagrams I have show a seperate regulator feeding ac to the headlights, and to a bridge rectifier which converts some of that ac to dc for the battery.
    Rob
    apriliaforum expert banzairx7's Avatar
    Jan 2009
    Austin, TX
    I had the exact same issue with an ATV I used to own. What happened on mine was the crank had ~1/16" of sideways movement. The inside face of the flywheel was hitting the stator coil. This was shorting the stator coil and causing all sorts of nasty spikes in electrical system.
    Jan 2008
    Quote Originally Posted by banzairx7 View Post
    shit! hope it's not that.
    rob i did smooth the lining so it looked equal all the way around. Think i may replace it but how can i be sure that if i buy another flywheel it isn't just as bad as the one i have. To be honest i don't want to buy any new stuff, i've got 7 weeks left on this heap of shit, don't want to pour more money into it than i really have to.
    I think i may get the flywheel with it aswell.
    Sam let me know if you find the problem please mate.
    Really stuck for what to do. Ideally i'd just want a new stator/stator plate, flywheel, CDI and regulator/rectifier. Would cost waaaayy too much though.
    So second hand seems to be my only option. But to i gamble another CDI on the fact that the second hand stuff won't also knacker the CDI.
    Jan 2009
    Plymouth, Devon
    I will let you know, I am going to see if the cdi breaks again in the next 2 weeks, if it does, my Dad will have a look at it.
    Your best option would be to go to a bike breakers to see if they have a CDI, I have just bought 2 from one, one as a replacement for the one that has just gone and the other for a backup lol.
    Jan 2008
    Quote Originally Posted by sam93 View Post
    fingers crossed i should be getting the CDI i have now replaced under warrenty. I only bought it 1 week ago.
    apriliaforum expert Aprilia af1's Avatar
    Jul 2007
    Near Kings lynn, Norfolk
    Quote Originally Posted by williamr View Post
    Rob
    Rob, wouldn't you get eddy currents in the stator anyway, because the magnet is producing an induced current, and so eddy currents are created from doing this?
    Aprilia af1 50 replica 1992
    rv6 engine, polini 47mm 70cc top end
    19mm carb, doppler er1 exhaust, derbi gpr50 cdi unit.
    malossi reed block standard reeds. 13/40 sprockets
    75mph at 11,500rpm clocked by a landrover freelander(probably more like 70mph).
    Other Bike: Aprilia af1 125 replica de-restricted from factory. SOLD
    Dec 2004
    Cheshire, England
    Yeah - of course you gett eddy currents, but theyre controlled. Lose bits of the magnets and you start getting all sorts of odd effects.
    Bourney - given your history with this bike, I'd get a CDI to get it running, then as you live in Stoke where there's a good buse service, and as you've only seven weeks to go, Id leave the bike unused so that you don't wreck anything else until you can get rid of it.
    Rob
    Jan 2008
    Rob
    I think you might be right mate. The only problem is the bus service dosn't run close to where i work.
    I'd really like to get it sorted though. I'd hate to pass it on to someone knowing that that CDI will blow within a week or two of them owning it.
    I wouldn't like it, so...... think i will get it sorted properly.
    Jun 2016
    Stoke on trent
    Hi. I realise this thread is old but I'm wondering if a solution was ever found. Having same problem myself.
    Replaced cdi 4 weeks ago (with 2nd hand one). Had new voltage regulator too. Did change stator plate but voltage regulator blew the new one so hence it being replaced and old stator went back on. 4 weeks on it won't start again . Anybody help?
    apriliaforum Junkie Scoop's Avatar
    May 2015
    Bristol. United Kingdom
    Presumably you now have no spark? Why did you initially replace the cdi and when you first replaced the cdi did it completely cure your problems?
    Get a multimeter and take some resistance readings. Disconnect the wires from the cdi. Reading between red and white should be 120 to 144 ohms and reading between green and white should be 700 - 840 ohms. The resistance between white cable and earth should be zero. In my experience the regulator and cdi are far less likely to be the culprits than the stator/rotor. For information, the wires to the cdi are as follows - yellow powers lamps, green powers cdi, red triggers cdi, white is earth and red/white is kill.
    Have you tried pulling the red/white kill switch cable from the cdi to see if there is a fault there?
    Jun 2016
    Stoke on trent
    Cdi was replaced as it burnt out few weeks ago. Tried to start bike and nothing. Had electrical guy look it over and he was the one who replaced cdi and voltage regulator. Less than 4 weeks on and at most 50 miles and same thing again. Bike won't start. Looked and no spark. Exactly like before. I should say had only owned a week before original problem. Guy came and fetched it back and it was him who repaired it. He won't have nothing do with it now just advised what he did before.
    apriliaforum expert Spudgun60's Avatar
    Dec 2013
    Devon UK
    Burnt out CDI units are a new on on me. I'm sat here trying to think how it is possible to burn one out.
    The generator pumps out AC voltage. The regulator dumps to Earth any voltage that the remaining electrical system doesn't require. The CDI unit gets a regulated voltage. The only thing that leaps to mind is a badly Earthed regulator. There's a fair number of people that think that only the three connectors do anything. Not so. The metal case of the regulator is the fourth connection. If the case doesn't have a good metal to metal connection, the surplus voltage can't be dumped to Earth. The upshot being: Things get fried.
    Well. That's my theory anyway.
    Gone, but not forgotten. 1999 RS50.
