Results 1 to 8 of 8
Thread: Gas cap air valve
    May 2007
    Long Island, New York
    Gas cap air valve
    I lost the venting hose and the little piece that clips onto the gas cap. I assume that was a one way air valve. It looks easy enough to put on a hose and a one way valve, MY question is.....Where do I get a one way valve? I don't want to get another aprilia piece bacause I assume it would always be falling off like the old one did.
    Micky Curry
    AKA MickyC51
    Feb 2007
    Charlotte, NC
    Any bike shop can order the valve for you. Clamp the hose with safety wire to the gas cap to prevent it from falling off.
    apriliaforum expert RXV_Poor's Avatar
    Jackson, CA
    A dab of super glue works also.
    02 Aprilia RSV1000
    07 Aprilia RXV 550
    06 KTM 525XC
    06 KTM 950 ADV S
    07 KTM 525EXC
    AMA, BRC, D36, CORVA, IMBA, STM
    Disclaimer:
    I'm impulsive, hard headed and sometimes really stupid. Please do not take anything I say or do as a "correct thing" or a "fix" as it could be harmful to your wallet or person. Never argue with an idiot, no one can tell the difference.
    CAL550 for Prime Minister
    King of Dirt 2009
    Magoo is my Hero
    apriliaforum expert crank1000's Avatar
    Jan 2008
    East Bay, CA
    It was a fairly simple design, and isn't secured in very well from the factory. Mine popped off, and I was lucky enough to see a ball bearing fall out, and onto the ground. Lets air in, but in the event of a tip, I guess it closes the hole it sits in. Anyways, get the plastic insert, and then run a shorty hose like the MXers run, and glue it all together. That way it will be less likely to snag on something and pop off.
    2007 Aprilia SXV 550 | 2002 Yamaha R1 | 2006 Honda CRF450x
    apriliaforum Member john savio's Avatar
    Dec 2006
    Lake Grove, NY USA
    I have been using this brass vent hose combo spinner and check valve for years and it works great at keeping fuel from spilling out should you tip or go down. It is originally from Kevins's Cycle in Noroton Mass. and they probably still sell it. It has been moved from bike to bike over the years. Highly reccomended!
    apriliaforum Junkie Oz215's Avatar
    May 2008
    QLD . Australia
    My eyes hurt.....
    Dec 2006
    Lake Grove, NY USA
    Sorry about the humgoid photo...It is killing me too!
    Nov 2008
    Jersey UK
    be carefull....my bike when I got it second hand had a little red mushroom type cap on the short rubber tube......at some point it must have got pushed down sealing the vent not letting any air in and it popped the valve in the fuel pump breaking it....needed a new pump after that....!
