Results 1 to 15 of 15
Thread: Reference Thread - Common Issues Info
    apriliaforum expert Fox Fader's Avatar
    Jun 2006
    Columbus, GA
    For easy reference place completely solved issue threads and I'll edit them to this first post.
    Top Tier Recommended Fuels
    Oil Classification Proper Oil Level Check
    Oil Pressure Release Valve Sticking
    Oil PSI Switch 1 2 (Thread Size) 3
    Service Manual downloads EFI Fault Codes
    No Spark
    ERRATIC START FUEL PUMP NOT PRIMING. Relay
    Bike Just Died While Riding (small line on fuel pump)
    Intermittent stalling, bogging, and poor idle
    Twin Plugs Fire Simultaneously, with proof
    Alternative Coils Capo Futura Thread (Same as Capo) GSX-R Alternative Coil
    Futura Fuel Leak Issue other than the OE Plastic Quick Disconnect
    Quick Disconnect Replacements, RSV thread Capo product Futura Product UK
    Leaky RSV Fuel Tank with links to other threads
    Fuel Pump Wiring Harness Potting Bulkhead Leak
    Fuel Filter Change Hoses, Clamps, and Fuel Pump Flange Sealant Discussion
    Fuel Pump Alternatives 1 Fuel Pump Alternatives 2
    Won't, Poor Idle
    Carbon Canister Removal CapoNord Gen 2 RSV Tuono
    Amperage Draw on Battery With Key Off
    Latest Battery Thoughts 10-2009
    Wiring Mod for Charging Issues
    Voltage Rectifier/Regulator Upgrade (Honda, Yamaha Rectifiers)
    Rectifier Brown Connector
    Stator Solution
    Stepper Motor Cleaning
    It was the Sidestand Switch
    Gen 2 RSV and Tuono Rear Brake Light Switch
    Futura and Caponord Dash Repair Dash Flickering at Startup Dash Blackout Repair
    Engine Speed Not Dropping When Closed Throttle. TPS Sensor Relearn (post #23)
    Sprag Clutch 1 (w/ links to alt parts) Sprag Clutch 2
    Coolant Flush Another
    Varying Temps, Overheating <<< Problem Remains, More Info
    EFI Flashing (sometimes) & No Code, Thermistor Problem Another
    Hydraulic Bleeding (best) Clutch Bleeding Procedure
    Intermittent Speedo
    Pulsating Front Brake Rotor With Pics
    Change Your Own Tires
    Front Wheel/Axle Proper Install Full Thread
    Quick Visual 01-02, 03 RSV Differences
    Dash Color Change, not Fut or Capo
    Accessing 2nd Map on Stock EPROM
    Showa Fork Service
    Rear Shock (Penske) Install, Futura
    2007 Tuono 1000R Factory
    Cored OE Racing Cans‡Map2‡Pazzo Shorty Knock-offs‡15-40‡AF1 Link Plates‡Aprilia Sliders
    Laminar Windscreen‡Lowered Pegs‡LED City and Tag Lights
    ProTaper Universal Low‡Clear Signal Lenses
    2017 High-Ball in Suede Nuclear Sunset Orange
    2017 Z125 PRO
    2001 Futura in Silver - Sold, after 8.5 years of service.
    Retired - DJ, Turntablist, MC, Creator, Video Editor and Mixologist.
    Cored OE Cans vs Leo Vince Titanium Vid
    Slammin' Tunes!
    HF152, 10-26954
    HF564 .024-.028
    Chrome extension to see photobucket blocked pics.
    %@*#&! hank's Avatar
    Earth
    Maybe in the 1000cc FAQ section?
    Jun 2006
    Columbus, GA
    Quote Originally Posted by hank View Post
    Yup you are right, maybe a Mod will move it.
    2017 Z125 PRO
    Slammin' Tunes!
    HF152, 10-26954
    HF564 .024-.028
    apriliaforum expert ThEGr33k's Avatar
    Jan 2008
    England - Yorkshire - Barnsley
    There is an other EFI flashing problem...
    Its a bit of a git. Basically there are no fault code and it seems random when the EFi flashes. Took me a while to find, but it was the switch on the Clutch that wasnt working. When you enguaged the clutch (let the clutch out) it would flash up. Simple fix is to just take the switch off of the clutch... you can replace it but I dont think it actually does anything!
    Anyway here is a link to the problem... Falco 03 is the one with the answer... Though it isnt straight forward, as you can tell with the first post the symptoms are a bit about the place.
    Hope this helps
    Jan 2009
    Lynchburg, VA
    Section labeled as "coolant flush" is the wrong link
    “Normal people ... believe that if it ain't broke, don't fix it. Engineers believe that if it ain't broke, it doesn't have enough features yet.” -Scott Adams
    apriliaforum expert SoulDaddy's Avatar
    Oct 2004
    San Marcos, California, USA
    Great idea, Troy.
    Jun 2006
    Columbus, GA
    Quote Originally Posted by ct.boaz View Post
    Fixed, thanks
    Quote Originally Posted by SoulDaddy View Post
    Great idea, Troy.
    Thanks!
    2017 Z125 PRO
    Slammin' Tunes!
    HF152, 10-26954
    HF564 .024-.028
    apriliaforum expert pdxmille's Avatar
    Sep 2008
    Portland, Orygun
    fuel filter replacement, step by step...
    http://www.apriliaforum.com/forums/s...d.php?t=198585
    Brad B.
    2006 ZX14 ***SOLD****
    2000 RSV Mille,***SOLD***
    May 2010
    Sweden
    Hi...
    The "link" that is suppose to show how to, (Click here for wire cutting. Click here for EPROM replacement)
    Is no longer working...
    Would appreciate if someone could explain how to do it...
    //Tom...
    Sep 2008
    Portland, Orygun
    Replacing the standard voltage regulator/rectifier with an upgraded one from an 08 Honda CBR1000RR
    http://www.apriliaforum.com/forums/s...d.php?t=211850
    Brad B.
    Jun 2006
    Columbus, GA
    Quote Originally Posted by pdxmille View Post
    Done
    2017 Z125 PRO
    Slammin' Tunes!
    HF152, 10-26954
    HF564 .024-.028
    Jun 2006
    Columbus, GA
    updates
    2017 Z125 PRO
    Slammin' Tunes!
    HF152, 10-26954
    HF564 .024-.028
    apriliaforum Member Jarv's Avatar
    May 2013
    Cairns, Australia
    Hi, was trying to open the links in the 'Accessing 2nd map on a stock EPROM' but the link is broken.
    Anyone point me in the right direction? Ta.
    Jun 2006
    Columbus, GA
    Added, Fuel Pump Wiring Harness Potting Bulkhead Leak
    Quote Originally Posted by Jarv View Post
    Some of this stuff gets moved and I can't find it, lol
    2017 Z125 PRO
    Slammin' Tunes!
    HF152, 10-26954
    HF564 .024-.028
    Jun 2006
    Columbus, GA
    Added
    2017 Z125 PRO
    Slammin' Tunes!
    HF152, 10-26954
    HF564 .024-.028
