Results 1 to 14 of 14
Thread: Anyone else have problems with voltage regulator
    Nov 2008
    I have 2006 Scarabeo 500 the dealer said to me that the voltage regulator is overcharging, did anyone else have this same problem?
    May 2008
    Minneapolis MN, USA
    What are the symptoms?
    a little north of Houston TX
    This is a link to another thread covering regulator problems. The guys that have the experience have covered this problem on other threads as well.
    Good luck.
    http://www.apriliaforum.com/forums/s...d.php?t=165354
    Nov 2008
    Quote Originally Posted by BennyMA View Post
    It is overcharging, it's charging back at a rate of 15.2 amps, which is why I guess my batttery needed to be replaced already.
    Oct 2003
    Hi magnet,
    Is it 15.2 amps, or 15.2 volts? Amprage is gooing to be dependant on how discharged the battery is, and whether or not there is a shorted cell in the battery. If it is 15.2 volts that indicates that the regulator is not doing its job. Charge voltage should always be smoewhere around 13.8 volts.
    Ride safe, Ride long.
    apriliaforum newb yager01's Avatar
    Nov 2008
    Hungary
    My AA 500 storage battery was wrong. This is my lucky. I have to buy an other (Banner 14Ah). It is more cheaper like an voltage regulator.
    Now the average charging voltage level is on 4000-5000 rpm 13 - 13.3V !!
    I tought that this was too low, so I checked the voltage level on the battery tap! I used a digital multimeter, which showed +1 Voltage than the board computer.
    I mean that the board computer cheat about 1 Volt. My regulator and my battery is perfect.
    Somebody has a "problem" with board computer like me..?
    apriliaforum expert vtwin_pilot's Avatar
    Jun 2004
    Atlanta - '08 Shiver
    Quote Originally Posted by preachp View Post
    Not the whole picture, exactly. Aprilia states in the manual:
    "Standard charge voltage: 13 15 V DC at 5000 rpm."
    That you're at 15.2 V (I'll assume you meant volts and not amps) means you're just a bit over spec, but if that reading is from your dash display, if it's like mine, it runs lower than actual by about 0.5V or so. So actually, you could be running as high as 15.7V or higher. As others have pointed out, looks like your regulator might be at fault. Check out the links they've provided for more info.
    apriliaforum Member Intrazel's Avatar
    Apr 2006
    San Diego, California
    Just change the OEM Aprilia/Piaggio/Ducati crap/pos regulator out to a new or low mileage newer Honda Unit (600-1000cc)from ebay for around $40 bucks, it takes about 30mins to remove/replace and you will have a much better unit , I did it about a year ago and have had zero issues since....
    ______________________________________________
    Vehicles:
    2005 Aprilia Atlantic 500++
    1999 Acura NSX++
    1998 Lexus SC400++
    1997 Dodge Viper GTS+++
    Nov 2008
    Hungary
    Quote Originally Posted by Intrazel View Post
    40$...Hmmm...I think this price is too low....can you give me some link from the ebay, because I didnt find...
    I found only with higher price...
    Jun 2004
    If you can't source the ebay one, you can get one at Electrex in the U.K. Here's a clip from an email they sent to me earlier this year when I inquired about a regulator for my Scarabeo. Should be the same part for the AA.
    From: Electrex World Limited [electrex@btinternet.com]
    Sent: Wednesday, July 16, 2008 11:37 AM
    Subject: RE: Aprilia Scarabeo reg/rec
    We can supply a replacement; we are out stock of the brown connector but you can use the connector from your original by unclipping the terminals. Price is 65.00 + shipping; please reply to this email if you wish to place an order.
    Regards
    Peter Houghton
    Tel: **44 (0)1491 682369
    Fax: **44(0)1491 682286
    www.electrexworld.co.uk
    Apr 2006
    Quote Originally Posted by yager01 View Post
    Sure...here is the exact unit on my Atlantic ....its been running perfectly for over one year now...
    starting at $29.99
    http://cgi.ebay.com/ebaymotors/06-07...Q5fAccessories
    Vehicles:
    1999 Acura NSX++
    1998 Lexus SC400++
    Jun 2004
    Well, now I see why the price is so low. The regulator's used and the seller's a salvage yard. As long as you know that going into it, no problem. Caveat emptor.
    It is also important to note that the Honda unit requires the wiring harness to be removed and replaced with the harness from the unit being removed from the Atlantic/Scarabeo. The Honda unit is not a 'plug and play' installation.
    Regards,
    MillCreek
    Snohomish County, Washington USA
    2004 Scarabeo 500: serial number 004 and built in July 2003 (Sold 5/2012)
    2008 Suzuki DR650 (Sold 5/2012)
    2012 Suzuki DL650A
    Two road, three mountain and one folding bicycle
    Apr 2016
    Harbor City
    Can anyone give an exact description of modifying the honda regulator to work on the aprilia atlantic 500?
