Results 1 to 11 of 11
Thread: SR50 Carburettor Diagram Anyone?
    Strood, Kent, England
    God so many problems with this bike! Right i dont suppose anyone has, or could point me in the direction of an annotated carb drawing for an 05' SR50 Carb? To be honest ive completely forgotten which hose goes where. Any help would be greatly appreciated
    apriliaforum expert ReplicaOwner's Avatar
    Southeast Indiana USA
    I sent you a pm.
    2000 SR50 Replica #1
    Minarelli 2-Stroke LC
    Martin Racing 72cc Big Bore Kit
    Ceramic Leo Vince ZX Exhaust Pipe
    Gates Powerlink Drive Belt
    4.3 gram Leo Roller Weights
    Yellow Leo Vince Clutch Springs
    Uni-Filter Two-Stage Pod Filter
    Martin Racing Dual Stage Fiber Reeds
    Martin Racing Aluminum Intake, Ported & Polished
    Tireflys Flashing Valve Stem Lights
    Fiber Optic Accent Lights On Belly Pan
    Needle E-Clip on 4th Notch - #115 Jet
    55+ mph on Flat, 62mph in a draft
    Old and New Start Up Video
    Work In Progress...
    Sep 2008
    carb diagram
    i've got a 99 sr 50 with a couple of hoses going to some place 1 has a red nipple and the same hose has a t on it , and the other 1 is shorter any ideas ?? if i can look at my bike and draw you up something let me know .
    There are 2 coolant lines, a vacuum line, fuel line and a oil line going to the carb. You can usually track down the other end to find out where they go.
    Here are some pics I just took. I should have washed it first but you should get the idea.
    Work In Progress...
    Alright thanks mate! Will have to give this a go once it stops raining
    Your welcome Rizla. I hope it gets you going in the right direction again.
    Can you scoot the kitchen table back out of the way until it stops raining? lol
    Work In Progress...
    apriliaforum newb Tunarfish's Avatar
    Jun 2017
    Sandbach
    Am trying to rebuild my sons sr50r that he was gifted to him, but am uncovering ten years of neglect, slow progress is being made, am trying to figure out where the heater lines from the carb connect to on the engine but can’t find a diagram which shows the connections, any help anyone?
    Jun 2017
    Sandbach
    Well after rebuilding the engine with virtually everything that comprises an engine (main bearings, crankseals, head, barrel, rings, little end, thermostat (( which was missing)), plug, cap, ht lead, coil, carburettor and auto choke,air filters, starter bendix, drive belt and rollers, think that’s it )it starts and runs no problem, is a bit reluctant pulling away from cold but soon settles and runs well, occasionally it refuses to revafter shutting off (junctions etc. ) and is sometimes a little “grabby” pulling away, can anybody point me in the right direction to resolve these problems as apart from this it’s a lovely little bike, it’s done 17500 miles which I didn’t think was a lot and has opened my eyes to two strokes. All help and advice gratefully received by a stressed out old fart.
    ontario
    try the fuel mix screw at 1.5 turns. if it is better try in or out another 1/4 turn.
    new sparkplug. compression is likely getting low at 18000miles so it could use a cylinder kit or a big bore kit.
    Jun 2017
    Sandbach
ID:	350358Thanks bud will try that, as stated have replaced
    head, barrel, piston and rings so they should be reet.
    ontario
    right / try the mix screw. the replacement jugs are often not finished up as much as new factory parts so the rings take longer to seal up. point is it might need to sit at 2 turns for the first two weeks then try 1.5 turns.
    synthetic red oil. new sparkplug if its old. keep the airbox stock or it will tune worse. screw the sparkplug wires on at both ends because they often are not sunk in enough then people get thin blue spark. take it off at both ends and mark full depth with tape.
    and clean the idle jet again.
