Page 13 of 42 FirstFirst ... 3111213141523 ... LastLast
Results 181 to 195 of 624
Thread: Ricks Motorsports Stator Version 2 - Thicker next step wires
  1. #181
    Feb 2008
    Quote Originally Posted by Diablo1 View Post
    No. The stock rectifier continues to draw current when the battery is fully charged. Then it takes that current and grounds it out. At high rpm, full current is flowing through the stator and to the rectifier to be grounded out. The high current in the stator creates heat in the stator. This new rectifier increases the resistance in the circuit as the battery voltage rises.As the resistance increases, the current flow in the stator decreases. The lower current flow in the stator reduces heat.
    So Diablo,
    What do you think? Do you think this would fix our issues for good? I know you cant be sure, but if heat is indeed the reason our stators are dying it should reduce the amount of damage that is being done to the stators. No?
  2. #182
    Quote Originally Posted by noskills View Post
    ...but if heat is indeed the reason our stators are dying it should reduce the amount of damage that is being done to the stators. No?
    And to the oil as well.
    Theknurl was working on a series regulator but I've never heard if he got it working. Though I haven't had any failures on my 01 other than connectors I would love to reduce the load on the engine +++ and get rid of the oil cooker. Would like to learn more about this unit and fit one if it does all that is claimed.
  3. #183
    Looking at that link just now I see this statement:
    "Blocks current to control voltage which reduces stator current resulting in lower temperature and less drag on the motor and more efficient operation"
    I believe this is a reference to alternators that have an electro magnet and not the permanent magnet like ours so I'm not sure this is going to do much for us.
    I wish we could have a regulator that would just disconnect the three stator leads when the battery is full then there would be no current flowing from the stator. Or some kind of variable resistors on the three leads rather shunting it to ground.
    Have any of you with failed stators replaced the rectifier? Maybe the problem is a bad rectifier causing excessive load on the stator.
  4. #184
    Jan 2007
    Hammond, Indiana - USA
    KZ, I believe this is a series regulator designed for a permanent magnetic three phase alternator. They link it to a a 3-phase PM alternator here:
    http://www.jpcycles.com/product/382-705
    I think this will solve the stator burnup problems. Someone should call these guys up just to verify it is a series regulator. Also we need a guinea pig to measure stator current vs rpm with a charged battery while using this new regulator.
    Hoosier, not hoser.
    2016 Tuono 1100 Factory
  5. #185
    Okay, Thanks for that. Definitely a permanent magnet type in the picture
  6. #186
    apriliaforum expert Reubens32's Avatar
    Dec 2004
    Little Elm, Texas
    Quote Originally Posted by rws06rsv View Post
    contact me if you have any questions about the install.....and no comments please on the tidyness of the install, I was in a hurry and there as not much there to mount extra bracing for the huge regulator.
    cheers!
    When you have a chance, can you explain how to connect the rectifier?
    There are are yellow and black wires that it normally connects to....and I'm concerned that I'll screw up the connection. Thanks!!
    2017 Husky FC350
    2014 Harley Road King Classic
    2010 RSV4 Factory (France's ex) Full Akra and Race ECU
    FOR SALE - 2004 RSV1060R Red & Silver, Ohlins 30mm Cartridge, Ohlins rear w/ Forged Wheels. Amauri built & maintained.
  7. #187
    Jul 2007
    Netherlands
    The user reviews don't look very promising to me especially the "stator died" part. But then again, most of the time only the dissatisfied users tend to post reviews:
    The first review:
    O.K. quality, but don't expect any help from Compufire in clarifying their unclear install instructions! You would at least expect some kind of an answer from them!!
    The second review:
    Item worked as advertised, except stator died within two months. Warranty is supposed to cover the parts for 2 years, but is a bit of work involved and time to pull and replace
  8. #188
    Jul 2007
    Netherlands
    This is some interesting reading on the electrosport website.
  9. #189
    apriliaforum Member rws06rsv's Avatar
    Nov 2007
    Australia, Newcastle
    The series regulator that theknurl was referring to was the Cycle Electric series regulator that I installed. So far, so good and when I get some time I'll compare the temperature of the stator side of the engine. Though I am seeing no connector temperatures above ambient and nor are the wires above what I call normal ambient (for around the engine that is). So Far I am VERY happy with this solution.
  10. #190
    Nov 2007
    Quote Originally Posted by mini_me View Post
    The first review:
    The second review:
    I don't quite understand why they refer to Compufire, is that another name for cycle electric? anyway, they refers to the stator, so I hope the regulator is better quality :-).....could also be that the guy was not competent, that could be a factor.
  11. #191
    Nov 2007
    Quote Originally Posted by Reubens32 View Post
    Reubens32, are you comfortable crimping all the connectors etc? make sure you have a good crimp tool designed for those connectors. If you don't mind wrecking the stock regulator connectors and wiring and the connectors are in good condition, then you can snip them off and crimp (and solder) ring connectors on to connect to the new reg.
    OR
    you could snip the connectors off the harness and crimp the ring connectors straight to the harness. this would be the best for minimising the number of points of failure and voltage drops but increase the chances of making a wrong connection or shorting something out while stuffing about mounting it. I left the orig. regulator intact, put it aside and did the following:
    on the stator side:
    Snipped off the 3-pin brown connector. crimped on new ring terminals and connected to regulator. you can connect any wire to any terminal, it does not matter. These are all yellow wires and there are no unique marks any any of them.
    On the DC output side:
    The two red wires on one end of the connector connect to the SAME '+' Terminal on the regulator. the two blue wires connect to the same 'GND' Terminal on the Regulator. The Green Wire is left disconnected.
    I found a 6-pin plug/socket set at the local auto-electrical supplier that was similar , apart from the locking clip, to the stock housing. I completely replaced the plastic housing. I inserted the existing crimped spade connectors still attached to the wires into the new male housing. They are arrange the same as they were originally. it is not too hard to get wrong, just keep the red to the positive and the blue to the ground side.
    have a close look at the photos I took. and if you like I will take another so you can more clearly see the colour of the wires on the harness side of the 6-pin plug.
    I am crap at explaining things so hope this makes some sense.
    Lach.
  12. #192
    Dec 2004
    Little Elm, Texas
    OR
    on the stator side:
    Lach.
    Okay...looks pretty straight so far.
    Please confirm this for Lach:
    BOTH BLACK Connect to the BLUE / Green Side
    BOTH RED out of Rectifier goes INTO the Solid Red / Red-white striped wire?
    2017 Husky FC350
  13. #193
    Nov 2007
    O.K. some results:.
    the current on each of the windings started at about 11amps and quickly settled to around 7A and fluctuated up and down just a couple amps....fans kicking etc. AC amps of course. maybe if I waited it may have dropped more...but I doubt it.
    the voltage at idle was about 25v across each phase.
    you can't just calculate the wattage output from the above values since you need to consider conversion losses and somehow work out the power factor here but my electrical engineering is way too rusty for that.
    Output:
    no matter what the revs were the output was a steady 14.7v.
    The current on the output of the regulator was between 10 an 17A. I waited about 10min but it would be good to measure this stuff after a ride...
    The voltage at the battery was 14.0V steady.
    How do these numbers sound? anyone want to measure the stock values?
    Oh and after 10 min I could still put my hand on the cover. but it was definitely hotter than anything else I could find....I really need to measure it after a ride.
  14. #194
    Nov 2007
    Reubens32:
    here are some pics of the wiring that should explain things.
  15. #195
    Apr 2006
    here
    Just wanted to chime in and say how interesting this thread is. A nail bitter for sure. Looking forward to some comparison/results, and if there is a simple way to better the not so great stock system.
    Keep it coming!
    part weight comparisons - click here:
    http://spreadsheets.google.com/pub?k...bA&output=html
    2000 Yamaha YZ125
    2002 aprilia Caponord
    2007 aprilia RSVR
    2008 KTM 690 SMC / Enduro R
