Page 42 of 42 FirstFirst ... 32404142
Results 616 to 624 of 624
  1. #616
    Jul 2014
    Earth
    i have installed rick coil and compufire rectifier for about 3-4months ago..
    since then.. the charging looks good.. on idle without load 13.5-13.8 take it out for riding on 5000-6000rpms i got very strong 13.8-13.9 like a stone.. it shows from koso slim voltmeter.. (didnt connect all the headlights, only 2 small dimmed lights)
    tried reconnect the headlight backed but only 1 side lowbeam.. the charging shows 12.8-12.9 on idle.. at 5000-6000rpms.. i get 13.3-13.6v..
    reconnect both headlight (lowbeam).. on idle it shows very low charging 11.5-11.9.. and will never recharging to high voltage... runs it at 5000-6000rpms and above.. it charged to 12.3-12.6 only.. once stopped at the traffic light.. the battery slowly drops back to low voltage 11.5-11.8v from 12.4++v.. (wondering what is gonna happens if the fan kicked in as well on the same time :'( )
    why it didnt charge on idle even the battery became so weak and does it normal with compufire rectifier???
  2. #617
    I would say it is definitely not normal. Something wrong somewhere.
  3. #618
    Jul 2014
    Earth
    or.. the rectifier is not working?
  4. #619
    apriliaforum expert Reubens32's Avatar
    Dec 2004
    Little Elm, Texas
    Quote Originally Posted by Kamm Matt View Post
    How about reinstalling the original REC and measuring voltage again from the battery at idle?
    2017 Husky FC350
    2016 Yamaha R1-M
    2014 Harley Road King Classic
    2012 Honda VFR1200F
    2010 RSV4 Factory (France's ex) on Misano MotoXP Ricambi race bodywork - Drop dead gorgeous!
    SOLD to Brian - 2004 RSV1060R Red & Silver, Ohlins 30mm Cartridge, Ohlins rear w/ Forged Wheels. Amauri built & maintained.
  5. #620
    Jul 2014
    Earth
    Quote Originally Posted by Reubens32 View Post
    yup im thinking the same too.. will remove the solder and try reconnecting oem rectifire back..
  6. #621
    Dec 2004
    Little Elm, Texas
    Gotta warn ya' buddy... there's a good chance that it isn't the REC. :/
    2017 Husky FC350
    2016 Yamaha R1-M
    2012 Honda VFR1200F
  7. #622
    apriliaforum expert steelman_2's Avatar
    Sep 2012
    Finland
    I did have a case that the quite new rectifier was blown, put the orig. back and it did run as should.
    In total this charging problem is easily solved I think, just few steps:
    - get rid of original wires and rectifier
    - buy a new well functioning rec
    - install it as near to battery as you can
    Name:  Retrifier install.jpg
    Name:  Retifier install 3.jpg
    - do new a hint thicker cables and straight cables to battery
    - have an extra generator in your pocket in case the original blows ( also new gasket to be ready for swap)
    I'm a (triathlo)nist, that's why I've joined A(prilia) & A(udi) club.
  8. #623
    Jul 2014
    Earth
    will try refit back the oem REC.. will see how it going..
    but before do that.. is there any method that we can check the rectifier either it is working or not? using multimeter especially for 3phase REC
  9. #624
    Brisbane, Australia
    I have found this to be an easy guide to follow to check the R/R.
    http://www.electrosport.com/technica...ting-guide.pdf
