Results 1 to 7 of 7
Thread: Schematic of oil flow in the engine
    Sweden, Germany
    Has anyone seen a schematic of how the oil flows in the engine?
    Would be nice to know for general understanding.
    apriliaforum expert rsredline's Avatar
    Dublin, Ireland
    I dont anyway, but you'll find one in a Haynes manual
    Sweden, Germany
    Thanks for the info.
    Possible for you to scan the specific pages
    Here is one out of the Falco training manual.
    1) Camshafts
    2) Cam Chain Tensioner
    3) Upper Balance Shaft
    5) Piston Cooler Nozzle
    6) Lower Balance Shaft
    7) Oil Tank
    8) Oil Cooler
    9) Oil Filter
    10) Oil Pressure Relief Valve
    11) Clutch Shaft
    12) Crankshaft
    13) Oil Pressure Switch
    apriliaforum expert VR-8's Avatar
    May 2005
    Sweden
    Can anybody tell me where the 0.8 nozzle is in the cases that supports the basket with oil? (The lower 0.8 nozzle in the picture).
    /J
    Sweden, Germany
    Search for clutch jet in the forum. Its behind a specific bolt.
    May 2005
    Sweden
    Ok, then I know where it is, thanks. Maybe if I plug that I can install the dry SBK slipper I have been designing.........;-)
    /J
