Page 3 of 3 FirstFirst 123
Results 31 to 43 of 43
Thread: New shiver problem?
  1. #31
    apriliaforum prov-nov slartibardfast's Avatar
    May 2009
    North Wales UK
    both mine leak, and in my dealers showroom their is a brand new black shiver with zero miles and a weeping brake cylinder.
  2. #32
    apriliaforum Member blange's Avatar
    Mar 2009
    Stockholm, Sweden
    Quote Originally Posted by kedzis View Post
    Few days ago i also noticed weeping fluid from front brake reservoir..
    Open the resevoice and whipe of the gasket. I had the same issue with my clutch, and whiping it of made the diff.
    Lange
  3. #33
    Mar 2009
    Copenhagen, Denmark
    Quote Originally Posted by slartibardfast View Post
    The best explanation so far came from bonehead... i quote "its italian, its crying for mamma"... that pretty much settled it for me, and i stopped caring about the weeping
  4. #34
    apriliaforum prov-nov Athenean's Avatar
    Jun 2009
    Athens, Greece
    It is a fairly common problem and becomes worse at high speeds.
    If tightening the screws and cleaning does not work, try this:
    There is a small groove on the lid. Try carefully to deepen it just a little, in such way that the gasket does not seal the groove. The ambient air must supplied above the gasket and not from below.
    That was the solution in my case. Just be careful not to "dig" the groove to much.
    The best bike is in my mind.
  5. #35
    Jun 2009
    I noticed that my brake container is seeping as well.. Not that clutch so far. I need to call the dealer and have them warranty that for me!
  6. #36
    Nov 2008
    happens to me as well...but the amount of leakage...is small..i check it dailly though...
  7. #37
    Jun 2007
    FL
    Old post I know, over the last fews day my DD has started weeping from both cylinders or at least enough to concern me. My question is how many others are just dealing with it, does a new gasket resolve the issue and/or is this something Aprilia can fix under warranty?
  8. #38
    Mar 2009
    Nimbin, Oztralia
    Short answer is yes - it can be fixed under warranty.
    S
    'Its a fine, fine line between pleasure and pain.' Chrissie Amphlett (RIP)
  9. #39
    Oct 2012
    Italy
    Just another Shiver weeping from both cylinders here. Both lids were replaced under warranty. Took my bike home and...surprise: still weeping after replacement!!! :-( ?????!!!
  10. #40
    apriliaforum newb Dierick's Avatar
    Apr 2012
    Belgium
    it is not a new problem, here in Belgium a known problem.
    I've also had my shiver 2008, all first shivers have had this problem until 2009. From 2010 the rempot and clutch cover revised and changed from sealing system. So I just ordered the new type cover for only 50 € for 2, and got after 1 year still no sweat more.
    Aprilia SL Shiver 750 / Alfa Romeo 147 1.9JTD 8v Squadra
  11. #41
    Oct 2012
    Italy
    yes but, being in 2012, they should have now installed revised lids in my Shiver, so I don't get why still weeping...!
    May I recognize revised lids by opening them and look inside? What the difference?
  12. #42
    apriliaforum prov-nov fordlatch41's Avatar
    May 2011
    Manchester UK
    It's a well known fault on shivers mine did it and I got two plastic parts fitted at my dealer under warranty, these plastic plates force the caps onto the rubber seals further and eliminate the problem.
  13. #43
    apriliaforum expert 25PSi's Avatar
    Sep 2009
    Livermore, No CA USA
    Very old problem. Nothing major.
    Disassemble, clean seals and around, assemble. If that does not help replace the lids. Easy Cleaning fixed mine long ago and it has not wept since.
