Results 1 to 5 of 5
Thread: Replacing clutch lever
    apriliaforum prov-nov 455bird's Avatar
    Apr 2007
    Ft. Collins CO
    I'm trying to replace my broken clutch lever, but I'm not sure how the barrel comes out. The locking pin is the small hex pin in the bottom of the barrel right? and this needs to come out first? I tried to loosen it but it feels like I'm about to break the hex key, so I just want to make sure I'm doing this in the right order.
    apriliaforum expert Magi's Avatar
    May 2006
    sarasota, florida
    that pin locks the free play adjusting screw and has to be removed.
    take a visual memory on that screw - it needs to be in its close aproxmate place when re instaled - to little play and the clutch will slip - to much play and the clutch will drag.
    trust me - ive done both.
    snug it up good when you replace it.
    use 1.5 mm allen key - it will come out.
    good luck.............d magi
    i wish i were
    where i was
    when i was i wishing i where here
    anonymous - shit house wall - dead horse alaska - (circa 1980)
    d magi
    Quote Originally Posted by 455bird View Post
    In many cases, Brembo used a Loctite or epoxy to fix the 1.5mm hex screw in place.
    Try a small pencil torch to heat it before forcing the screw loose.
    apriliaforum expert prillernut's Avatar
    Apr 2004
    Chapel Hill, NC
    Tony
    '05 Honda CR250R (2-stroke baby!)
    '03 Tuono ex-owner
    '97 Kaw Concours
    '74 Maico 400
    Apr 2007
    Ft. Collins CO
    Thanks for the help. A little heat and it came right out.
