Results 1 to 6 of 6
Thread: Shift Indicator
    apriliaforum Member 750SHIVER's Avatar
    May 2008
    Sterling Heights, MI
    Shift Indicator
    Does anyones shift indicator seem really slow? The one im speaking of is the electronic display that tells you what gear you are in.
    If I start off it will show 1st gear right away. The moment I shift into 2nd the display just goes blank. If I keep in second long enough it will re-appear. The same goes for 3rd through 6th. Sometimes it will not appear at all unless I shift down a gear and them back up!
    I'm thinking I have someting messed up. Anyone having the same issue?
    Thanks,
    Keith
    apriliaforum expert nostatic's Avatar
    Apr 2005
    lost angeles
    just the way it works. It is a sensor and is doing calculations. takes awhile to register. Feature, not a bug.
    apriliaforum newb fr3ddan's Avatar
    May 2008
    Sweden, Borlänge
    Hi
    I think the problem is that you don't let the grip of the clutchhandle. You have to let it go all the way back otherwise the sensor will not send the signal to the display.
    But the sensor is really slow as Nostatic says.
    I'm from Sweden and my english is'nt that god but i hope you understand what I mean
    This was the first post for me in this forum
    apriliaforum expert makrand's Avatar
    Aug 2007
    Jungle near Byron Bay, Australia
    Welcome Fr3ddan.
    I was gonna say the same thing.
    Don't "ride the clutch".
    On mine it takes about one second to show the gear once you have let out the clutch fully.
    Makka the lurker
    When the going gets weird
    the weird turn pro
    May 2008
    Thanks,
    You guys were correct. I was driving with my fingers just resting on the clutch lever. All it takes is just a little pressure and the display will go blank.
    Thanks again!
    Keith
    May 2008
    Sweden, Borlänge
    Thankyou Makrand I hope I will enjoy to be here...
    --->750 Shiver, Fine to see that the problem went well for you, just fun to help you out.
