Results 1 to 3 of 3
Thread: Turn Signal Problem!
    apriliaforum Member Tubba's Avatar
    Sacramento/San Luis Obispo
    Exclamation Turn Signal Problem!
    I just installed these new LED turn signals with the relay and when I hit the turn signal switch, the dash makes a wired noise and both of them go on like a harzard light
    Jul 2007
    OC
    Hi Tubba.
    Use that search button.
    You will need to add 2 common diodes to make it work correctly.
    One of our forum members has done an excellent job of posting the schematic and parts list that you will need to complete it.
    apriliaforum Junkie Cheesy's Avatar
    Oct 2005
    Wittering Peterborough, UK
    i fitted led;s to the rear of mine few weeks back
    i used a universal flasher relay suppilered by motraax to replace the o.e one and works a treat
    04 Tuono Fighter
    Renegade 2-2 system
    Renegade Air Kit
    PC III Custom Mapped
    Gabro V5 chip
    16/44
    Full lenght Belly Pan
    + other bits & pieces done
