Results 16 to 30 of 37
Thread: Links
    It appears that he domain name caponord.com is now up for sale.
    Folks, if you have a domain name and forget to re-register it, the domain name reseller vultures are out there waiting.
    Going rate for an interesting domain name is $5000 US.
    apriliaforum expert XPADREX's Avatar
    Nov 2003
    Ohio, USA
    That kind of bullshit makes me want to start a sight called http://www.iownafriggingcaponordbutc...cbuymepage.com
    apriliaforum Member Mr. Lee's Avatar
    Nov 2005
    On the Edge
    AtomicTape
    Howdy!
    I found some Magic at the Boat show.
    It is called: Atomic Tape.
    http://www.ATOMICTAPE.Com
    I Didnít know where to post this item.
    It is heat proof to 500/deg.
    Insulates to 8000 Volts
    Withstands 700/psi.
    Air & Water Tight
    AND, it is cohesively self bonding with no stickem Glue.
    This stuff comes in different colors, and it looks like a roll of electrical tape.
    Lee
    Nov 2005
    On the Edge
    Reflections
    I got an email about mirrors. Check it out, there is some fancy alternatives along with an original OEM.
    http://www.mirrordeluxe.com/?landing=20060531
    apriliaforum expert Prankster's Avatar
    Jan 2006
    Ponca City, Oklahoma, USA
    Loki J. Prankster
    In my life, it's not the choices I make, it's the chances I take that influence my life the most.
    apriliaforum newb okantezer's Avatar
    Apr 2006
    turkey
    http://www.sahibinden.com/search.php...xt%5D=caponord
    There is a lot of Caponord's second hands parts on this b2c web site. But it's in turkish.
    Pls also search the site with "capanord" as keyword
    Morgan Territory, CA
    Dyno-tuned Tuneboy Maps for the Caponord
    I have made my dyno-tuned Tuneboy custom maps available for the Caponords.
    Original maps available thread.
    Dyno-tune report thread
    Latest TuneEdit software revisions & info thread.
    Catfish ...
    Oct 2003
    Portland, OR
    I would like to see a sticky for the common major fixes for the leading electrical problems with the Capo, i.e. Brown connector, starter solenoid, and rectifier. I searched for and found them but it took a long time.
    I am The Motoman and I have approved this message.
    '15 Caponord 1200 TP
    '07.5 Black Tuono
    '06 Ducati ST3
    And a few more...
    "It's too late to apologize..it's too late.." One Republic
    "Is it too late to say Sorry?" Justin Bieber. Yep. It is.
    "It's too late to say you're sorry". Zombies 'She's not There'.
    Oct 2004
    Verona (Italy)
    the bigger club caponord owners..
    www.apriliaontheroad.com section caponord of course..
    Banned
    Mar 2010
    Australia
    RE : Links
    Hi,
    Its a new and good idea. Keep it up with this updation.
    Thanks,
    Mark Janet
    apriliaforum expert quicktoys2's Avatar
    Feb 2007
    Patras, Greece
    http://www.tutorochainoiler.com/about.html
    cheap chain oiler ........
    ___________________________________
    Rubber side down, shiny side up!!
    03 silver Caponord
    H & B crash bars
    Ermax windshield with Laminars lip
    Givi Maxia Monokey top box
    Aprilia handgaurds
    Handle bar risers
    Center stand
    Hyperpro springs - front and rear
    Cooma N.S.W.
    JohnG.
    '02 Capo.
    Latest Tuneboy Information for Caponord Owners
    Catfish ...
    New Information as of Nov.8, 2010 below ...
    Tuneboy is written, sold, & supported via their web pages. They ship the orders from their home in Australia. Wayne & his wife (& new baby) are the whole company.
    Wayne races Triumphs & has friends with current-model KTMs. These are the motorcycles that he can readily test his software changes against. I do not believe he has ready access to a Caponord or Futura anymore. This is probably the reason that he is silent to Caponord owners requesting support. He can't duplicate your issue at his location, so there is little chance he can fix a Caponord owners problem in his code. He is very active on the Triumph tuning forums.
    I do not recommend that Caponord owners actually install the most current version of the Tuneboy software that is sent to you with your order. It probably will NOT communicate with a Caponord correctly.
    The versions of Tuneboy that we here on this forum have been successful with our Caponords are available online from Tuneboy users; The older 2.4 version that works best with the older tuneboy serial-port interface cable (like I have), and a newer 3.9.1 version that works best with the modern tuneboy USB interface cable.
    Tuneboy is geeky software with an external hardware interface (the cable). It has a steep learning curve, even when reading the (not-obviously Triumph-dominate) documentation several times. Those Caponord owners who are not geeky enough to figure it out with help from this forum, will NOT be happy with Tuneboy's Caponord support.
    If you can get one of the versions above working with your PC, cable, & Caponord we can probably walk you through any actual use or download issues.
    January 13, 2011 Update - TuneECU versions of my catfish maps are now available at the same web page.
    Good luck!
    Catfish ...
    2011 revised Catfish maps ...
    I have made a few changes to the map I'm running in my Caponord. All versions of my maps can be found at the usual place; <http://www.endorphin-express.com/capo/maps.html>.
    Minor changes have been made in several areas, but the most noticeable change is a softening or smoothing of the torque at low rpm, idle to 2000 rpm. I wanted my Capo to have a smoother throttle response at low rpms and small throttle positions. This makes it easier for me to be smooth when I have a passenger on the back.
    I can now close the throttle and let the motor drop to idle in any gear without any drama or having to pull the clutch lever in. Just crack the throttle open to slowly & smoothly accelerate away.
    I can't guarantee the same results in your Capo, as they all flow a little differently. This low-rpm smoothness was best achieved with the exhaust CO set to 3% at idle on _my_ Capo. Your Caponord may vary.
    Good luck,
    Catfish ...
    apriliaforum expert GH_services's Avatar
    Aug 2010
    watford, herts
    thats great, thanks catfish - just one question, assuming all is equal in terms of riding style/engine loads/IFT settings ETC,ETC would you expect more, less or the same fuel economy?
    p.s. the rev limits in your updated map are back to standard - is this intentional?
  1. Chain links
    By HarmanKardon in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 07-23-2007, 03:10 PM
  2. Crap! 108 links is too short!!!
    By kimmyhendrix in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 02-21-2005, 05:23 PM
  3. 05 Map links
    By Bikeaholic in forum RST1000 Futura (all years)
    Last Post: 01-19-2004, 09:34 AM
  4. Kouba links for lowering Pegaso-3 ?
    By dofferhoff in forum Pegaso 650 Cube and IE
    Last Post: 07-25-2003, 09:14 AM
  5. Chain Questions... 112 Links?
    By iceman in forum SL1000 Falco Forum (all years)
    Last Post: 01-07-2003, 12:46 PM
