Originally Posted by
zane
If you follow the manual, you'll have no problems. The photos are very good in showing all operations. The only issue that the manual does a poor job explaining relates to the retaining rings. The rings that 'lock' the forks in the frame of the scooter are very thin. The rings that hold the plastic cap into position in the slider are much heavier. You can very easily do what I did and that was to swap them when I was reassembling the slider. I discovered this after I had one of the rebuilt forks installed on the bike. I noticed that if I applied downward pressure on the fork, the ring would pop out of the retaining groove and release the fork. I was able to remove the retaining ring that held the cap in place and swap it out with the one that holds the fork on the frame without removing the fork. I have no idea what would have happened if I would have driven the scooter for any distance with the retaining rings reversed, but I sure would not want to see what would happen if the fork fails...
After riding the scooter a number of times since I did the job, I can say that the cornering and handling has improved greatly. In fact, the scooter seemed to be too stiff in the corners at first. I was accustomed to the forks having very little tension. I went with a 20 weight oil for the forks (230 cc/fork). This was the heaviest grade the dealer handled (an aprilia dealer). The manual calls for a heavier weight oil. At this point, I'm glad I used the 20 weight.
