Results 1 to 2 of 2
Thread: Oil Change On A 02 Rs50
    california
    How Or Where Do You Drain The Oil.
    Thank You.
    Mar 2007
    Trabuco Canyon CA
    edit #1*disregard post I thought it was a 250*
    Edit #2
    heres a diagram of the left side case (if looking at the headlight)
    http://www.af1racing.com/store/Scrip...idCategory=894
    #10 is your drain plug or see http://www.apriliaforum.com/techtips...s75/fluids.htm picture #2 for drain location
    Step 1:
    get someone to hold your bike in the level position or throw it on front AND rear stands
    remove the fill cap and remove the drain plug. drain all your oil out
    Step 2:
    Picture 3 shows the level screw
    remove the screw and reinstall the drain plug
    Step 3:
    fill with oil slowly until the oil comes out of the level screw hole.
    Step 4:
    reinstall the level screw once all the oil stops seeping out and reinstall oil filler cap.
