Results 1 to 10 of 10
Thread: I rode my 2004 rsv1000 in the cold and now it wont even attempt to start
    Oct 2007
    I went to start my 04 rsv1000 after sitting for about a week after riding it in very cold temp, now the battery is fine reading about 12v and when i goto start it, the bike wont even make any attempt to start as if the battery was dead, any suggestions......
    Banned Morgan's Avatar
    Jul 2006
    England!
    Mine used to show 12v when it was close to dying (5-6 ignition switches to get it on).
    Are you sure you haven't got anything other than a weaker understimulating battery? Does your engine try to turn over at all?
    Gummed spark plugs, loose contacts/wet etc come to mind, but it's probably something simple....
    apriliaforum expert vtrandall's Avatar
    NorCal
    try putting the battery on a tender overnight and then try starting it in the morning...
    -Randall
    .....Sed quis custodiet ipsos custodes?
    Three great forces rule the world: stupidity, fear and greed
    Dec 2007
    so cal
    do a load test on the batt. if you don't have a load tester take it to local auto store and have it tested [bring batt only not the bike] and keep in mind volts and amps are two diffent things.you can have 12v reading on your batt and only2 amps without amps you have nothing.also check connections for corrosion and "tightness" as well as the fluid level in batt.if all that is good then the fun begins.good luck and keep us posted
    apriliaforum expert Tdawg's Avatar
    Oct 2005
    Pangæa
    what they said test battery, charge battery, check connections amd for corrosion.
    i had similar problem and a new starter relay was the fix, so check that too.
    you can get the ape one or aftermarket one from af1
    http://www.af1racing.com/store/Scrip...idproduct=2538
    apriliaforum expert Rutan's Avatar
    Nov 2003
    Frisco, TX
    It has happened to others so make sure it is not in gear.
    If it is not in gear, battery is good, check out the starter relay since they have a history of going bad.
    Marcus
    apriliaforum expert mossback's Avatar
    Oct 2003
    Seattle, WA
    The starter relay could be suspect, have it checked.
    There is no better place to find good advice about life, business dealings and fear than from people who have gone through it before.
    IT Services
    RED 2004 RSV1000R
    PCIII usb custom map
    Full Arrow headers and Ti slipons
    Michelin Power One tires
    MotoBit's rearsets
    16\43 gearing
    F.Fabrri double bubble
    Removed Flywheel
    Showa forks with Ohlins internals - Thompson Suspension
    Ohlins Steering dampner
    Ohlins rear shock
    45,000 miles
    New timing chains.
    1:35's at Pacific raceways
    2:12's at Miller Motorsports AMA track
    apriliaforum Junkie bull*ramus's Avatar
    Apr 2004
    England
    if the battery's fine but you've had it out, give the tip over switch a shake and re-try it.
    Oct 2007
    Where is the tip over switch? sorry to sound dense this is my first aprilia I've always had hayabusas before this
    Oct 2003
    Seattle, WA
    Quote Originally Posted by Jmilbutler View Post
    Its under the passenger seat. The trunk. Black box with two wires, I have mine filled with 90 weight oil. Bumpy rides can kick it on suddenly.
    IT Services
    RED 2004 RSV1000R
    MotoBit's rearsets
    16\43 gearing
    Removed Flywheel
    Ohlins rear shock
    45,000 miles
    New timing chains.
