Page 6 of 16 FirstFirst ... 45678 ... LastLast
Results 76 to 90 of 227
Thread: Brown Connector Problem - Yes, we are affected
  1. #76
    Troy NY
    Michael B I think you have a second plug. My voltage was all over the place (13.8to 14.1) before I fixed my fried plug. After the fix ,my voltage was a steady 14.3 v. The first plug look good on mind too. Second one was fried. My #256 is close to yours. Check for a second plug!
  2. #77
    apriliaforum expert toycloser's Avatar
    Apr 2007
    gainesville, fl
    Guess what happened to my bike today.
    Yep I stopped after a high speed run and stinky smoke was coming from my bike. When I saw that brown goo dripping from the bottom, I knew exactly what it was
    28 bikes in the group and which one broke down?
    2007 Aprilia Tuono (black) SOLD
    2007 Suzuki DRZ400SM (black)
    2005 Suzuki V-Strom (black) 50k miles
    notice a trend?
  3. #78
    apriliaforum Junkie _CD_'s Avatar
    Oct 2007
    Phoenix, AZ
    07.5 built in Scorze, one connector, looks fine so far. I'll check this regularly as I've had some of the other issues materialize (like the coolant hose being damaged by the plastics).
  4. #79
    Aug 2007
    Mountains of New Mexico
    2007 US (2006-Euro) #163. Single connector down behind the coolant recovery bottle- lookin' good at 1600 miles. Rerouted the wires and connector away from the lower engine block out towards the front of the recovery tank- away from engine heat- and where it's readily visible without removing plastic "beauty" covers and recovery tank. Also packed both sides of connector with dielectric(sp?) grease. Gonna keep a close eye on this possible problem area...
  5. #80
    apriliaforum Member MichaelB's Avatar
    Nov 2006
    SoCal
    Quote Originally Posted by Scooter3 View Post
    Yes, I have two connectors. Both are fine... for now.
  6. #81
    Oct 2007
    Spain
    I checked mine and they are also fine after 10.000 kms!
  7. #82
    apriliaforum Member TuonoBen's Avatar
    Jan 2006
    Ranst, Belgium
    Just on time...
    Thanks to this thread I kept watching my T for the brown problem.
    And yes, today was B(rown) day. Not as ugly as some of the victims in this thread but with my broken dynamo still in my mind...
    Italian motorcycles, Chianti Classico or Brunelli di Montalcino, the best a man can get....
    TuonoR '06
    TDM850 '00
    TDM850 '98
    GPZ500S '96
  8. #83
    apriliaforum Member Pieman's Avatar
    Herts, UK
    Quote Originally Posted by altotuono View Post
    Same for me. I measured the voltage and it's a solid 14.3v so it looks like I'm OK for now but will keep an eye on it.
    Thanks to Joe250 for all the info. and to everyone else for posting their experiences.
    _______________________________
    Simon
  9. #84
    Apr 2008
    london
    i had this problem and caused me loads of shite fix it quick before it leaves you stranded
  10. #85
    Apr 2007
    gainesville, fl
    My mess:
    Easy fix. I just took some duct tape off another guys body work and finished the ride
    notice a trend?
  11. #86
    apriliaforum expert pbas's Avatar
    Feb 2007
    Stockholm
    Quote Originally Posted by toycloser View Post
    My mess:
    .....Easy fix. I just took some duct tape off another guys body work and finished the ride
    Yuck !! Gross!!
    That does it! It's brown-connectorectomy-time.
    Don't want my baby looking like that.
    Black -08 Streetduty
    Black -07.5 RSV converted track biatch
  12. #87
    apriliaforum expert Priest's Avatar
    Mar 2007
    Croatia
    Quote Originally Posted by pbas View Post
    Yuck !! Gross!!
    I checked mine. After 10.000 km nothing... Waiting...
  13. #88
    Sweden, Germany
    Coming from the Futura forum where the brown connector problem is well known.
    As far as I know, after soldering the crimped contacts in the brown connector, no one has reported melted connector after that.
    Just an alternative for those who want to keep the connector.
  14. #89
    apriliaforum expert Falco9's Avatar
    Wakefield, West Yorkshire, England
    Has anyone at all (either side of the Atlantic) had this problem back to their dealer under warranty?
    So many posts on this, but nothing about the cure that Aprilia are (or should be)applying. If anyone has had the repair done under warranty, was it just a simple replacement or is there an improved / modified part fitted?
    F9
    "I've spent 50% of my life riding motorcycles, the rest I've wasted"
  15. #90
    apriliaforum Member Uriel's Avatar
    Oct 2007
    Watford, London
    Had a butchers at mine since she is getting a spring clean. Can only find one brown connector which is located near the reg. Did some digging around but can't see another one anywhere. Will have a look at the voltage and see what I find, hopefully I might not be affected.
    Had a butchers and mine is holding bang on 14.34 volts. Makes up for my magnetic wheels.
