Results 1 to 13 of 13
Thread: over heating on long runs
    Jan 2008
    this is proberlay my owen fault i was going olong the dual carage way on my rx 50 polini 80cc bore kit, 21mm carb, full arrow i was going between 70 and 75 then my bike cut out lost compression. got a lift home took the head of id burnt a hole in the piston and all the rings were stuck in the piston. from the burnt piston i take it i need a larger jet. is it possible to get a replacement 50mm pollini piston becuse the barrel is in very good condition not scored or worn and would save alot of money, could you suggest a good size jet one that wont eat pistons.
    apriliaforum expert Azzroid's Avatar
    Apr 2007
    Do a plug chop to find ur jet size. Or just buy a few bigger in like increments of 5, then go through them until u get to a good size then buy some more.
    For example: go through 80,85,90,95,100 etc then wen u get a decent one say 95 get a 94 and 96, then if 94 is good work from there. Pretty simple really just gotta get the right mix
    2002 RS 50 Tetsuya Model £475
    Added So Far:
    New Battery:£15
    Chain, Sprocket, Back brake, Front Brake, Fork seals, Indicators, Head light, New Front and Back tyres Full service, MOT: £250
    New Exhaust (Metrakit RK Race Exhaust): £143.95
    New Main Jet (Size: 59): £3
    New New Main Jet (Size: 75): £3
    New 70cc Big Bore Kit with bore'd out carb: £200 fitted professionally
    Malossi Carbon Reeds: 29.95 euro's
    Dellorto 21mm carb: 68.50 euro's
    TP CDI: 36.50 euro's
    Metrakit Clutch: 42.50 euro's
    14 tooth sprocket: 9.50 euro's
    Doppler inlet: 16.50 euro's
    Want:
    Re-spray
    Dec 2004
    Cheshire, England
    Plug chop at WOT to get the main jet correct, then chop at part throttle to set the needle properly.
    What state is your plug in? Too soft a plug burns holes in pistons even with correct mixture.
    While 50s are usually at WOT, no engine likes sitting there for a long time on a dual carriageway. Next time, ease back occasionally.
    Rob
    Jan 2008
    what is a plug chop?
    apriliaforum Junkie Vikter's Avatar
    Oct 2007
    Raleigh NC
    Quote Originally Posted by reggie View Post
    Checking the sparkplug to make sure it is not white (lean) or black (rich). It should be a golder brown color.
    Dec 2004
    Cheshire, England
    Ride up a slight hill in top gear, accelerating at full throttle. Dip the clutch and hit the kill switch to stop the motor. Hold the clutch in while you stop the bike and remove the spark plug. If it's white, the mixtures too weak. If it's black, it's too rich.
    This tells you weather you've got the correct main jet. It can also indicate an air leak (lean) or a dirty air filter (rich). Whjen you have the spark plug showing a golden brown colour, repeat the chop at 1/2 throttle. This time the condition of the plug will tell you if the needle setting is correct. As this is deprendant on main jet size there's no point in correcting the needle until you have the correct main jet.
    For really accurate setting, use a colourtune kit in conjunction with a dyno. That's expensive.
    Rob
    apriliaforum expert PallOlavsson's Avatar
    Jan 2008
    Washington D.C
    Willamr, many guys on this forum are kinda harsh against you, cause you dont like underagers driving..
    But i gotta tell you
    You know your shit!
    Cheers.
    -Páll Ólavsson
    Bike:
    Previous bikes owned:
    Aprilia SR 50 Morini Ditech '03
    Kawasaki KX 125 '05
    Aprilia RX 50 '05
    Yamaha FS1
    apriliaforum expert nopainnogain's Avatar
    Oct 2007
    warwickshire
    you need to get your ctlinder measured accurately,i doubt if it is 50mm as you say,aprilia bbks generally have 49.7mm piston size.
    I MIGHT NOT HAVE A QUICK BIKE...BUT I GOT A QUICK CAR!!
    apriliaforum expert 46robbie46's Avatar
    Feb 2008
    Romford UK
    I was having the same problem with plugs burning out. Try checking that your exhaust isn't coked up and shitty inside. Once i'd cleaned it out with caustic soda and brute force it ran sweet as a nut.
    Oct 2007
    This happened to me but :
    I never burned the piston
    The rings weren't stuck, but they had completely gone on one side (and not the other)
    My barrel was fine
    It was over a much shorter distance.
    Plug chop at WOT reveals lovely coloured plug. Do you think that the previous owners have thrashed this bike to bits and i just sent it over the edge or could it be 100% my fault?
    I was doing indicated 55 at 11,000ish rpm, backing off occasionally, it was actually when i was backing off that it cut out and lost compression.
    (It did still have some compression when i got it home..in the back of a taxi)
    apriliaforum expert bourney2007's Avatar
    Jan 2008
    England, Stoke-on-Trent
    Quote Originally Posted by slasherslade View Post
    My barrel was fine
    How the hell did you fit a rs50 in the back of a taxi, and how did you get the taxi driver to agree to doing it?
    Quote Originally Posted by Dom.C View Post
    My Sister's boyfriend is riding it at the moment, his 2 years of restriction is up so it's running 100 brake at the moment.
    hahahahaha dom you fucking legend.
    If you don't get it, read it whilst thinking of nothing but sex
    Oct 2007
    I own the taxi. Thanks for answering my question.
    Jan 2008
    oh right lol
