Anyone bought one of these? Any good?
http://tinyurl.com/ywm5bc
Nik
Nik
been looking at those too , im sure someone has bought one , dont know if they have fittet it yet
samesh..t diferent day
Just fitted mine today (cheers Gary!)
But i've found when the bolt is done up, and it is done up correctly, there is a 1.5mm gap between the shoulder of the bolt and the face of the sidestand.
This means the top of the stand should be made a fraction thicker.
Other than that a very easy fit and a very good finish.
should therbe a washer between the bolt and the sidestand ?
I'm using the original bolt which is shouldered. The gap is at the head end.
Can't put a washer there because it'll cover over the hole for the sidestand switch!
Washer on the other end will make no difference due to the shoulder between the thread and the shank of the bolt.
Options are- thicker plate or take 1.5mm off the shoulder of the bolt.
Or do what i've done and pack the gap with silicon grease and leave well alone! The switch is functional and the stand works......
It doesn't entirely fix the cause of the problems - namely the small angle of the mounting bracket (20° or so).
Imo, only a US sidestand bracket (with longer sidestand, that extends out much further at a flat 45° angle) fixes this for good.
It sure is much better than the laughable Original EU-spec thingie though!
Olivier
Black Aprilia Falco SL1000 - EU model 2000, the faster one
Suzuki GSX 1200 Inazuma, 2000
Yamaha-Belgarda SZR 660 (x2: 1996 and 1997)
Kawasaki KE 175D (x2: 1981 and 1982)
Vespa Primavera 125 (x2, both 1974)
Honda CB50J (1979)
& several other scoots and mopeds...
There are several options for improving the sidestand. Try doing a search both here and on the UK R.S. site.
Briefly you can use a Firestorm stand, some sort of GSX stand. A tilting bracket. A US spec Falco stand etc.... etc....
Thanks guys. Might see about a US spec replacement from AF1 perhaps.
cheers,
Nik
Chris
Probability factor now 1:1, normality has been returned. Anything you can’t deal with now is your own problem
Same here. Much better but does make you choose.... cut away 3rd mounting point of stand or grind away small section of frame...
Chris
get a firestorm stand and switch off ebay
mine cost 15 quid including delivery
bolts straight on and plugs into wiring loom - you will have to swop over the mounting bracket btw...., is a straight swop
very easy - about 15 minute job in total, and works very well
Sounds ideal. When you say you have to swap over the mounting bracket, do you mean you have to swap it for the VTR one?
Nik
no, you take the aprilia mounting bracket and apply the firestorm stand to it - once you have one in your hand you will see what I mean
very easy, very successful mod I think - was the first thing I did to my falco
