Results 1 to 10 of 10
Thread: Oil Drip on Futura?
    apriliaforum prov-nov JadeRider's Avatar
    May 2007
    Houston, TX
    Oil Drip on Futura?
    Good day
    I have not been able to ride the Fut for the last 4 to 5 weeks, as I recover from surgery. This morning, as I was leaving for church I noticed a small puddle under the bike and what seems to be an oily substance. I just placed a plastic pan underneath to collect the drip and look. It does show where the puddle was earlier.
    Being fairly new to this game I wonder if this is something that can happen as a result of not riding it, and secondly, I assume this will require work?
    Any feedback and ideas is greatly appreciated.
    JadeRider
    Jeremiah 12
    5 If you have run with footmen and they have tired you out,
    Then how can you compete with horses?
    PA USA
    depends on how you lube the chain. I use an auto oiler and every once in a while excess oil drips onto the ground just about where your spot is.
    It's possible your clutch slave is leaking. But that would be a pretty big leak. You'll know pretty quickly as you will not have a clutch. rick
    Dec 2003
    Elmont, NY
    could it be from the front cylinder? I know people mentioned a breather hose that drips onto the front header. I get small amounts of smoke from the front from time to time if the bike sits for a while.
    Tom
    apriliaforum expert teachers's Avatar
    Apr 2005
    Montrose, PA
    How about the oil pressure sending unit?
    Mine leaked when it was new and was replaced.
    BTW: Are those the original Met Z4 tires? If so, your you may have more than an oil leak in your list of future problems.
    -Duane
    IBA #28362
    2004 Futura - Silver
    Tigcraft Slip Ons - Jet-Hot coated exhaust & AF1 H-Pipe - PC III - Destricted w/ Mille Boot & Evoluzione Air Filter - Colder Fuel QD - Borella Regulator - Heli Bars - Geelong CF tank protector - Throttlemeisters - Headlight Mod & HID x3 - RaceTech fork parts - Zumo 550 - ne-oublie's Pivot Covers - R&G Sliders - PC-8 fuse box - SmartTire TPMS - some goodies for the FAMSA tank bag - provisions for Gerbings - a voltmeter waiting to be installed - new Pirelli Stradas waiting to be installed
    Me and my RST:
    May 2007
    Houston, TX
    Yep
    Those are the original tires to be changed very soon. Bike was not ridden and has not been ridden for 5 weeks like I said, so this is a spontaneous leak there. Looks like a tow to AF1 will be in orders
    JadeRider
    Jeremiah 12
    apriliaforum expert futfalc's Avatar
    BTV
    [QUOTE=
    -Duane[/QUOTE]
    I got over 7,500 miles out of my original tires.
    I could have gone another 1,000 everyone said to get rid of them.
    I thought about the tires i used in the 70's and i thought the z4 were pretty good tires.Everything in perspective. Plus i was being frugal...
    In the 70's i was happy to have air in my tires!!
    apriliaforum expert RPB's Avatar
    Apr 2004
    Netherlands aka Holland
    At that spot there are a lot of possibilities:
    - all of the above, plus
    - oil cooler hose
    - drain plug of oil tank
    - stator cover
    - oil filter cover
    - carter drain plug
    - etc
    I suggest you remove the lower LH fairing panel (requires removal of upper) and check
    Rob - '01 Rosso Flame
    "Riders Create More Problems Than Motorcycles Are Designed To Handle" - Keith Code
    Apr 2005
    Quote Originally Posted by futfalc View Post
    I
    In the 70's z4s would have been phenomenal. Best thing you could get back then was hard ass Dunlops.
    - Sam Shepard
    -Neil Peart
    '02 Ash Black RST (w/ black wheels!)Stainedtunas,AF1 H-pipe,PCIII,EVO race airbox kit & filter, Mille intake boot, Tuono forks w/Ohlins revalve, Ohlins Rear Shock,Brembo 4 pad calipers and Radial Masters,(999) 320mm Sunstar rotors, Goodridge steel lines, Borella Reg/Rec w/silver solder crimp upgrade, R&G Frame sliders (one used), Zumo 550 GPS, Flux Capacitor, Hubcap Diamond Star Halo, Vintage BEF plate bracket, T'meisters, Michelin Pilot Road 2s,.
    2009 Ducati 848 track bike
    Dec 2003
    Elmont, NY
    Quote Originally Posted by RPB View Post
    - oil cooler hose
    - stator cover
    - oil filter cover
    - carter drain plug
    - etc
    I agree its best to pull stuff apart and look for a source, just work your way up.
    Tom
    apriliaforum expert FUN DOG's Avatar
    Sep 2005
    Georgia, U.S.A.
    I'll bet it's the water pump seal leaking oil from the weep hole on the right side. Well documented and I have the problem too. The water pump shares a seal with the oil side and legend has it the seal wasn't installed properly at the factory. There's a whole thread on it in "1000cc f.a.q."
    I keep a paper plate under that spot and the leak never gets any worse. A couple of drops after every ride and that's it. I top it up about once a month and no worries. If you want it fixed, kzmille is supposed to be the man to do it (see 1000cc f.a.q. thread).
    That's my guess.
