Results 1 to 9 of 9
Thread: Identify what is in my gear oil..?
    apriliaforum Member loaded's Avatar
    Aug 2007
    Sunny San Diego
    Oh man,
    Gear oil has about 300mi on it -
    Is that coolant... ?
    bike, bikes, bikes!
    apriliaforum expert OZRS's Avatar
    Feb 2006
    Sydney, Australia
    Looks like it, its pretty cloudy. I hope that white crud was in the bottle before you drained the oil
    I'm not a Gynecologist, but i'll take a look
    Back Massager Expert William the Third's Avatar
    Oct 2003
    Asheville, NC
    Quote Originally Posted by loaded View Post
    Oh man,
    I doubt it is coolant, but it probably is water. If you run a catch can it could have got water in it after a rain or wash and then sucked in the gearbox from there.
    #1 Forum Loser
    Aug 2007
    Sunny San Diego
    The only thing that keeps me positive about my rebuild is OZRS's sig .
    bike, bikes, bikes!
    apriliaforum prov-nov akrs's Avatar
    Fremont, CA
    creamy oil
    Is that white stuff leftover from the plastic bottle you used or your engine?
    My experience with this is most common is to get gas in the bottom end from petcock not shutting off and carbs overflowwing into catch bottle. That doesn't 'look' like gas in the oil, but... Do you use a catch bottle? I assume not since you are on the street.
    Do you run coolant or water?
    "You are never too old to have a happy childhood"
    2001 Aprilia RS250 Tetsuya Harada
    2003 Duc 999S
    2002 BMW F650GS Dakar
    2004 Duc 749S
    2007 Aprilia Tuono R
    apriliaforum Member bunny's Avatar
    Aug 2005
    before i jump into any conclusion. was the bottle free of water before you pour the oil into it ? if it was dry, probably OZRS is right.
    apriliaforum expert VinCBR900's Avatar
    Near Loughborough, UK
    As above, assuming residue is not fine metallic stuff?
    May 2007
    N.Ireland- Ballymoney
    looks like some sort of metallic filings to me! but it might just have already been in the bottle!
    stick yer finger into the crud and rub it between youre fingers if it feels like grinding paste then its part of you're gearbox metal!
    Trevor
    Dec 2005
    maybe it's liquid from the cooling system
    check the water pump's seal
