Page 3 of 3 FirstFirst 123
Results 31 to 38 of 38
Thread: Deliver dem ~PIZZAA
  1. #31
    apriliaforum expert V6jules's Avatar
    Jun 2007
    Sunny Dunstable
    the pickups are under the right side cover and are not exposed to any shit so wouldnt have thought that would be a problem.
    have you tryed changing the plug (cant be arsed to read back through to check again. it only takes 5 mins)
    you wont damage the con rod squirting petrol in... unless you some how managed to get enough in there to get a hydraulic lock which cant be compressed and thus bends the con rod but not so likely on a 2t and not if your just spraying petrol up the bellmouth
    Modifications; 34mm carb, Foam filter, Carbon reeds, 16-40 Renthal sprockets and Gold O-ring chain, Dominator twin Headlight, Mini alloy indicators, Single seat alloy tail fairing, Shotgun rear lights, Wavey disc, Arrow exhaust (got JL but its wank so took it off) Polished stainless bolts everywhere
  2. #32
    apriliaforum expert Vale's Avatar
    Sep 2007
    London
    Just got in from a 10 hour shifty at the pizza place
    lol them bikes are so joke like semi automatic
    I've changed the plug yeh, it could be a problem with the ignition system but I really have no idea I just wana pay somone else to do it lol
    it could also be the carb like andy said
    I think my next step is puttin the old stuff on (first the carb) then if it dnt work with the old carb the old barrell etc
    ANND if that dont work then fuck it guna send it off to somone who knows
    what there doin ( pj)
  3. #33
    apriliaforum expert Sheene7's Avatar
    Mar 2006
    The finest county
    How much would you charge to deliver to West Yorkshire?
    '08 SXV 550 / 05' Kawasaki ZX636
  4. #34
    apriliaforum expert kd sweety's Avatar
    May 2007
    Essex
    If i ever offend add "I am a little girl, spare my feelings" to the thread to save any tears and red/yellow cards...
    lol! funny guy
    Quote Originally Posted by jameskrs50 View Post
    if u want a harley, buy a harley, dont buy a Chingwung Buttplug 200.
  5. #35
    apriliaforum expert kezajones's Avatar
    Feb 2006
    Guernsey,Channel Islands
    it will fire if the seals have gone, just wont hold pressure and will bog out almost straight away, being that the rs isnt crank case inducted
    My Bike:
    Vertex Flat Top Piston and VHM Head
    34MM Carb
    JL SS/CF Single
    Skidmarx Double Bouble Screen
    Oxydo Paint Job
    HPI Twin Map CDI
    V Force 3 Reed Block And KTM Manifold
    TNT Power Filter
    Yellow Rim Tape
    Ard Solo Seat
    Renthal Front And Rear Sprockets
    Gilles Black Adjustable Rear Sets
    Galfer RSV Wavey Disk
    Carbon Hugger
    Custom made Braided Brake Hoses
    Stan Stephans Tune (wanktakuclar)
    Ohlins Forks
    Ktm/Beringer Caliper
  6. #36
    Jun 2007
    Sunny Dunstable
    look i wouldnt change you barrel back as i cant see that causing a problem. all the piston has to do is go up and down inside it. its not like it can be mechanically wrong.
    try the old carb though
  7. #37
    Sep 2007
    London
    Roger that
  8. #38
    Wolverhampton west mids
    Sent you the photos Jamie to your Email Address
