Page 8 of 9 FirstFirst ... 6789 LastLast
Results 106 to 120 of 128
Thread: LED Signal Fix.........
  1. #106
    apriliaforum Junkie KbomonFalco's Avatar
    Boise Idaho
    Sid,
    Are you sure you have the front LED's wired correctly? LED's are directional and only work when the pos(+) and neg(-) are correct.
    I know nothing about the newer Aprilia's and how they are wired. Do they use a CAN bus now? If you have a bulb warning light, it's safe to assume there is a bit more to the circuit now. If you want to PM me the wiring schematic I can try and come up with something for you. Cheers!
    2001 SL1000 Falco
    2000.5 RSVR Mille
  2. #107
    apriliaforum newb Sid.davo's Avatar
    Jan 2012
    W.Mids, UK
    Hi Falco,
    Thanks for the reply. Did nothing different front to back (or so i thought) Familiar with the principle of the LED being directional but my electrical brain was over-riding the common sense telling me +ve is red and the usual common is brown leaving black/blue to pair. Apparently not the case!!! I need me an auto electrics cause i reckon
    Needless to say i'm embarassingly fixed for now.
    Sid
  3. #108
    Boise Idaho
    LOL! No problem Sid. That has NEVER happened to me.....
    It's good to be "humbled" once in awhile. Helps keep you in check. Glad you got it sorted.
    2001 SL1000 Falco
    2000.5 RSVR Mille
  4. #109
    apriliaforum expert Nooj's Avatar
    Oct 2004
    Newbury, Berkshire, UK
    The wiring colours threw me before, dark blue is the return for Aprilia, not black like it is for the rest of the world :-/
    Shiny Bike Syndrome - Preventative motorcycle maintenace <- <- visit my website for more details.
  5. #110
    apriliaforum prov-nov Tikitua's Avatar
    Jun 2011
    West Auckland. New Zealand
    It works with the 1N4004 diode. All i had kickin round so just used them, SWEET!!!!!!!!!!!! Also works with the three blade led flasher, You just need to connect a ground wire to the frame and crimp a female spade connector to the other end and hook it up to the ground blade on the flasher,. "piece of piss" as we say in NZ. Cheers
    "The west is the best, the west is the best, get here we'll do the rest." Q Jim Morrison.
    2005 tuono R
    Tigcraft 80mm slipon and mid pipe dual link mod.
    Dark smoked double bubble.
    GABRO F255 CHIP.
  6. #111
    apriliaforum expert velowood's Avatar
    Nov 2004
    No. California
    Hey, an unrelated question but I'm trying not to blow things up. LED's are directional, as has been said. But if you hook them up backwards, are they ruined, or do they just not work?
  7. #112
    Boise Idaho
    They just won't work. The only way I can see ruining them is to put too much current through them.
    2001 SL1000 Falco
    2000.5 RSVR Mille
  8. #113
    apriliaforum expert anzacinexile's Avatar
    Jan 2005
    UK South Coast
    Quote Originally Posted by KbomonFalco View Post
    Quite correct.. They're diodes so reverse biasing them wont hurt at all but excess current most certainly will
    Chris
    Probability factor now 1:1, normality has been returned. Anything you can’t deal with now is your own problem
  9. #114
    apriliaforum expert Falcopops's Avatar
    May 2006
    Townsville Australia
    Quote Originally Posted by anzacinexile View Post
    Interesting. I have most definitely fried a few LED's in the past by connecting them the wrong way round, not indicators or the like which perhaps have idiot proof protection on them of some sort, but out of the packed individual items.
    The data sheets have a max reverse voltage and current and I thought that was the issue, so a little more info would be appreciated.
    An example is at a party I was taping LED's to 3V calculator batteries popping them in a rubber glove, blowing up the glove and chucking them in the pool, but that's a whole other story. Thing is a mate was helping and although I told him about the long and short leads, he got a couple the wrong way and they were toast.
    "I like to put a little silicone grease on the seals, too, to keep them looking young and fresh like a prom queen." - SoulDaddy
  10. #115
    Boise Idaho
    Sorry, I read it as "diode". LED's are a bit different than diode's. They actually work (light up) on about 3v, and require current limiting resistors to operate properly at 12v. Power diodes like the ones being used in this thread (IN series) are pretty much ..... as you said, idiot proof. LED's on the other hand can be a bit fickle. I have seen some that fail prematurely. Each color has different tolerances. Reading the data sheet for the respective LED can help explain what will damage them. Don't ask me to decipher that stuff. I'm just a tinkerer. LOL! I can only see having issues when working with LED's individually. Any production indicator will have all the proper circuitry to prevent failing.
    2001 SL1000 Falco
    2000.5 RSVR Mille
  11. #116
    Jan 2005
    UK South Coast
    LED's are light emitting DIODES. Not as tough or robust as rectifier/power diodes but diodes just the same.
    As with all things, abuse them enough and they will fail, the only difference between the two types is the amount of abuse they can take before they go bang
    Chris
  12. #117
    apriliaforum expert Lttlcheeze's Avatar
    Jul 2005
    B-More, MD
    More like a small fizz, but I guess bang works too.
    '03 Falco Bought New on 4/6/07:
    Custom paint, Powder Coated RSV Swing arm, RSV Shock, Anodized Rear Sets, Ti Hardware, Anodized (Blue) Fork Caps, SL Carbon Cans, SL Carbon Chip, Custom Airbox w/ K&N Filter, Evo Clutch Slave Cyl., CF Front Sprocket Cover, Rear Hugger, & Chain Guard, GP Shifter, Tuono Rear Brake Master Cly., Evo Clutch Slave Cly., Evo Fender Eliminator, RSVR Mirrors (custom mounts), Custom Blue Dash, HID Headlight, Smoked Tail Light Lens, Integrated Turn Signals into Taillight, LEDs in Headlight & Taillight, LEDs Thru-out, SuperSprox +2 Rear Sprocket, Ariete Grips... (i'm sure there is more)
    Bill
  13. #118
    Jun 2012
    London
    Just done this mod after all four indicators flashed and it knocked out my fuel light. Now the indicators work as they should and I've got my fuel light back thanks for the write up.
  14. #119
    apriliaforum prov-nov hatred's Avatar
    May 2005
    the dumbest place in the world... Connecticut
    I slid my Mille into a wall at the track, and the result was the blinker switch to the left flashed all four blinkers. The blinker switch to the right did nothing. I disassembled the switch, swapped the relay (behind the dash) and nearly traced all circuits. This mod brought my blinkers back to working normally, but the dash light doesn't work. Also, one my resistor packs (super bright leds) on the rear blinkers was damaged. Therefore, I had to build a new resistor board to get it working. I have a full led set up, and got it working with resistor packs, originally.
    I only add this because the rewiring on the dash got my blinkers working, but did not fix my dash light. Also, resistors were still needed to get my led turn signals working. Living in CT means few people use their turn signals, so I'm fixing this for my own amusement. I can provide specs/pics if anyone wants to see how to build their own resistor boards.
    He who stays on the defensive does not make war, he endures it.
  15. #120
    Jul 2005
    B-More, MD
    If you did the dash mod, the only thing you still need is a LED (aka Electronic) Flasher relay and you can eliminate the Resistor packs. Those only add a load so the relay can switch. With an LED relay they aren't necessary.
    Did you try swaping out the dash light with a bulb that is known to work? It could simply be busted, and causing all of the problems you were having.
    Bill
