Page 1 of 4 123 ... LastLast
Results 1 to 15 of 51
Thread: my bike died today
    apriliaforum Junkie gweedo's Avatar
    Cornelius OR
    my bike died today
    I was at a red light in neutral hands off all the controls and it just died? It wouldn't start after that.. I pushed it off the side of the road and checked some fuses under the seat and they look good.. as I was standing there wondering what I was going to do I saw that I happend to be across the street from a small mechanic shop for bikes, so I pushed it over there and expained to them what happend and me and a tech did some basic checks and it has spark, has gas in the tank, seems to have compression, the battery went dead pretty quick trying to turn it over but they had a charger, anyway I can't figure this out? could there possible be no fuel pressure? can a fuel pump go out just like that? is there a fuse somewhere I don't know about? any ideas would be great I am going to open her up tomorrow morning and kinda need a direction to go..
    Thanks,
    Josh
    apriliaforum Junkie micknwop's Avatar
    Mar 2006
    Seattle
    Quote Originally Posted by gweedo View Post
    can a fuel pump go out just like that? is there a fuse somewhere I don't know about? Thanks,
    Josh
    when you turn the key and the right switch is in the on position can you hear the fuel pump going?
    Cornelius OR
    nope...
    apriliaforum expert styx's Avatar
    Bedale, North Yorkshire / Riyadh, Saudi Arabia
    In that case I'd check if you get voltage to your fuel pump. If you do, your pump'd prolly had it. If there's no voltage, time to get the wiring diagram out.
    Steve
    When the eagles are silent, the parrots begin to jabber.
    Winston Churchill.
    Cornelius OR
    can someone tell me what the little black box under the seat, right behind the battery is? it looks like the fuel pump wires go to it? i took it off to look at it and it is rattling? like there is something broke inside it?
    apriliaforum Junkie Sensei's Avatar
    Oct 2006
    New Zealand
    That is the knockover switch turn it on its side a couple of times then put it back onto it mounting bracket & try bike again . Mine fell off while riding & bike was dead till I seen it laying on its side . Hope this helps things
    Cornelius OR
    thanks sensei, i opened it up and figured thats what it was, however thats not the problem.. I got the fuel pump out of the tank and now I need to know how to test it.. I plugged it in to the bike while out of the tank and there is nothing coming from it, its not trying to prussurize anything during key turn on.. is there a way to test it out of the bike? I want to make sure its the pump and not the wiring to the pump.. I dont have a meter to test the wires the pump connects to..
    thanks,
    Josh
    apriliaforum expert apriliamaster's Avatar
    Perdoni padre, perche ho peccato
    Did you check the dreaded sidestand saftey switch?
    When mine went out the samething happened to me. This is a common problem with our bike, in fact AFI sells a bypass for that very problem. Do a search on this issue, you can also cut the wire and bypass the saftey switch all together. But then you will always have to remeber to put your kiskstand.
    apriliaforum prov-nov Raimo's Avatar
    May 2007
    Sweden
    Mine did the same thing when the second ignition fuse popped. It's in the fuse box on the right of the dashboard, at least on the older bikes mine is a -99.
    Everything but the fuel pump worked and it took a wile before I took notice of the fuse but when I did I saw it was broken. Changed the fuse and the bike started again.
    /R
    Cornelius OR
    Kickstand is bypassed, fuses all look good..
    thanks guys..
    apriliaforum expert Cryogenic's Avatar
    Aug 2006
    Lancing West Sussex
    Fuel pump relay maybe? Mate has similar problem, seems to occur when bike has warmed up, I've tried everything I can think of up to now so will be intrigued to what you find, I'm looking at replacing the relay next and see what happens....seems to me that whatever I do it runs fine for a while then starts playing up again, I'm wondering if something is breaking down when hot, so relay next on list
    " A wiseman speaks if he has something to say...a fool will speak because he wants to say something "
    apriliaforum expert Beau1K's Avatar
    Aug 2005
    Huntington Beach, CA
    Check the kill switch
    Also...make sure your hoses aren't squished/crimped under the tank
    "Tuono doesn't want to gently take your hand and guide you on a trip, it wants to rip it off and run away with it! I always get the feeling that to ride a Tuono you have to be a real man, prepared to fight it every step of the way, where as on the Triumph you can have an off day and not be left feeling inadequate"
    "Tact is for people who aren't witty enough to be sarcastic"
    JOIN ME ONAND FOR SOCAL APRILIA GROUP RIDES & UPDATES FOLLOW ME ON
    Cornelius OR
    never thought to check the kill switch, i'll have to open that up when i get off work.. will the kill switch kill just the fuel pump? (or is that how it kills the bike?)
    the relays under the tail were swapped and didn't do anything.. with the pump out of the tank plugged in I can here the relays click but nothing with the acctual pump..
    I have a new pump on the way via Motocorsa.. $250 bones with a new seal.. so i hope i can find something real easy wrong and not need to mess with a new pump or pay for it..
    apriliaforum Member gmcenroe's Avatar
    Aug 2007
    San Mateo, CA
    I had similar problem with my bike, it just died when I got to a stop sign at the top of a hill. The previous owner had a battery that was just too small. I replaced the battery and the starter relay with the yamaha one and haven't had any problems since then.
    2001 Aprilia RSV Mille R
    Evo airbox
    Acculign rearset
    dual Akras
    Factory Pro chip
    Cornelius OR
    i just bought a new battery from AF1 not even 3-4 months ago? i got the mille R battery..
    though the battery seems to lose charge very quickly, a couple turns of the key and she is dead..
