Results 1 to 3 of 3
Thread: mixture screw
    apriliaforum expert dellenty69's Avatar
    Dec 2006
    somerset
    mixture screw
    seems u lot never replyed to my last question in my other thread i am forced to start another thread... lmao
    anyway if the mixture screw is turnt all the way in, will it cause any damage in low or high rpm?
    my flat spot almost goes when its screwed all the way in!
    The Hammer - Officialy The Tool Of The Pikey!
    jolly moto, with pollished ally end can!
    standard air box back on. (runs better)
    15 tooth front JT sprocket
    40 tooth PBR rear sprocket (polished)
    xenon HID H1 100watt 5000k bulb
    xenon HID H3 130watt 6000k bulb
    LED White Wedge Inverted Side Light
    peugeot 307 LED flush side repeaters
    bright white halo rings in headlight.
    paint renovation coming up.
    Quote Originally Posted by Cheeseweasel View Post
    Im not judging you, Im telling you your a fucking idiot.
    apriliaforum expert shellndan's Avatar
    Jun 2007
    caerphilly
    by flat spot are you refering to between 6 and 7 thousand rpm? wouldnt reccomend having it all the way in. im no technical genius or anything but is there for a reason dude.
    pain is temporary, bones heel, and chciks dig scars!
    Dec 2006
    somerset
    yea between 6-7rpm, cdi mod has been done tho,
    its just it seems to run better if its all the way in.
    i though it was just to allow air into the engine to ignight fuel. and if its all the way in, and still running surely that would meen i am getting enough air to burn the fuel?
