Page 1 of 6 123 ... LastLast
Results 1 to 15 of 82
Thread: Tuono Oil Change Pictorial
    Jun 2007
    Florida
    I recently did the 600 mile service on my Tuono and I thought I would document it as there is very little about the procedure online. I may be off with the allen key sizes, but it should be pretty accurate...
    My contribution to the site. Enjoy!
    I did the 600 mile service on my '07 Tuono today. The main item was an oil change. There are no procedures for this on the web, so I figured that I'd do one. Here goes...
    Disclaimer: Workring on your bike can be dangerous. Proceed at your own risk. Information below is provided for entertainment value only. etc. etc.
    Start with an '07 Aprilia Tuono
    This is the area that we will be concentrating on
    You will need 4 quarts of synthetic oil 10W50 or 15W50, a cartridge filter, and a couple of o-rings
    Put the side panel in the service position by removing the 4mm allen screw, loosening the pivot 4mm allen and using a 12mm wrench to loosen the extension bar
    Remove the lower fairing. One 4mm allen screw on each side and one front and center
    Here are the items we will be addressing.
    1. Remove the oil tank drain bolt using a 10mm socket (Inspect/replace crush washer)
    2. Cut the factory clamp where the line goes to the oil tank screen (Replace with a hose clamp)
    3. Use a 27mm socket to remove the oil pump screen. Clean with brake cleaner. (Inspect O-Ring)
    4. Remove the oil filter drain plug using a 7mm allen socket
    5. Remove the two 6mm allen screws holding the filter cover (Inspect O-ring)
    Remove the filter and inspect the housing
    Reassemble everything.
    Fill with 3.25 quarts, no more, no less. Then start bike and let idle for 1 minute. Top off oil tank, using a total of roughly 3.75 quarts.
    Put it back together and go for a test ride of 5 to 10 miles. Shut off bike, wait 1 minute and recheck oil level. Adjust if needed.
    All done
    '07 Tuono
    Honda Mini Trails X2
    www.StreetKnights.com
    apriliaforum expert Harry H's Avatar
    Sep 2004
    Sunny Surrey
    OHI....ARAIHEAD.... Just so you know. This is what a useful thread should look like.
    Thanks Holeshot
    apriliaforum Junkie Solo's Avatar
    Jan 2006
    Yokohama, Japan
    Dude,
    U are one detail freak. Care to join my pit crew?
    No wit
    Jun 2007
    Florida
    Quote Originally Posted by Solo
    Dude,
    Are you covering airfare?
    apriliaforum expert tuono07's Avatar
    Mar 2007
    Cuming GA (Atlanta Area)
    Love it Man!!!!!!!!!! I've had the first two changes done at the dealer. I'll be doing them myself from now on.
    apriliaforum expert Tee-Dub's Avatar
    Vancouver, Washington USA
    If he was that detail oriented he wouldn't leave his tools and fairing hardware strewn about the garage floor!
    As far as the oil screen, it is an "every other" item. You can remove it from the engine side and unscrew it from the oil tank without having to cut the factory clamp.
    Nice garage btw. I love the floor and have always thought about painting mine like that.
    For my money it doesn't get any better than when he sings, "When a man loves a woman". I celebrate his entire catalog.
    apriliaforum Junkie System6ix's Avatar
    Jun 2007
    Your Sister's room
    Thanks so much! This is perfect!
    Cheers,
    S6ix
    '07.5 RSVR silver/red
    The set-up: 15/42 gearing | Leo Vince Gen III hi-mounts | EVO airbox kit | a bit of cabon fiber
    apriliaforum Junkie S.Ga.Rider's Avatar
    Dec 2006
    Georgia
    Thanks for the write up. I have changed mine once but didnt remove the front fairing or clean the screen. I was going to do it next time , I just have to find a 27mm socket.
    Trust in the Lord with all your heart and lean not on your own understanding; in all ways acknowledge him, and he will make your paths straight. Proverbs 3:5-6
    Jun 2007
    Florida
    Thanks guys, I'm happy you guys find it useful. I wish I documented the charcoal cannister removal
    Here is a my license plate modification that I did. Easy to duplicate.
    http://www.apriliaforum.com/forums/s...d.php?t=121542
    Tee Dub - I'll try to be beater in the future. I tend to group my tools in the spot I'm working on them. The floor paint kicks ass; it's very easy to clean and I do alot of messy work on my race car and other toys...
    '07 Tuono
    apriliaforum expert FUN DOG's Avatar
    Sep 2005
    Georgia, U.S.A.
    Excellent, but you didn't show the removal of the oil filter drain bolt to the lower right of the filter cover. You had an arrow pointing to it. There's quite a bit of oil behind that bolt and it really ought to be drained. Also, it's less obstructed on your Tuono than it is on my Futura. Maybe you did it and forgot to include a picture.
    Anyway, thanks for posting this. Really shows where everything is. Wish I'd had it when I did my first change...got by on the old Falco rundown.
    Jun 2007
    Florida
    Quote Originally Posted by FUN DOG
    Step 4 above (Between the screen and cover pics), but I didn't get a picture
    '07 Tuono
    Sep 2005
    Georgia, U.S.A.
    Quote Originally Posted by Holeshot
    OK, I see it now. I wish you had included a picture as that is the toughest part of the change. How did you keep oil off the exhaust collector when it drained out. I use aluminum foil to catch the draining oil.
    Jun 2007
    Florida
    I just tucked the hose back into the rear set and the oil dropped straight down. No issues with the exhaust for me. Bike was on the side stand, not a center stand FWIW.
    Maybe I'll do an edit and add a picture with the wrench on that bolt. I'll try to do that tonight.
    '07 Tuono
    Jun 2007
    FL
    Thumbs up
    Holeshot, great job on the documentation, much appreciated! While you are re-editting the pictures could you add the torque specs in there? That was the toughest part of the change for me. Looking them all up on the site or where ever I could find them took me almost twice as long. If you don't have them I would be happy to look them up again. (should have wrote them down somewhere)
    Admins: maybe we could make this a sticky or add to your tech tips?
    -Trip
    Sep 2005
    Georgia, U.S.A.
    Oh, I see. I forgot about the center stand. That makes sense.
