Page 1 of 3 123 LastLast
Results 1 to 15 of 43
Thread: Water in oil? Possible causes.
    May 2007
    Florida
    Other than a head gasket, what else could cause water to get into the oil?
    Would a water pump seal leak water into the oil?
    I appoligize, I'm sure alot of my questions have already been discussed. But the search feature is not working.
    thanks
    apriliaforum expert king karl's Avatar
    Nov 2006
    Bradford, yeh baby
    May 2007
    Florida
    Thank you much. That is Ultra helpful.
    apriliaforum Junkie Devine's Avatar
    May 2007
    the sunny North East of England
    Karl, did you get yours sorted?
    Nov 2006
    Bradford, yeh baby
    He's on with it as we speak, hopefully just waterpump seals but we'll see
    May 2007
    cool, keep us posted on the outcome
    How many miles does your have on it now?
    Nov 2006
    Bradford, yeh baby
    Im guessing around 1000, theres no speedo connected up
    apriliaforum expert cal550b's Avatar
    Dec 2006
    North Yorkshire
    Quote Originally Posted by king karl
    it spends most of its life lying down .and needs the new cat shit grip tyres from bridgestone
    Nov 2006
    Bradford, yeh baby
    Its looking like the water pump housing seal that Cal put a diag up on the other thread was the culprit
    Its been run up to temp and all seems fine ( touch wood)
    May 2007
    good result then if thats the case
    Nov 2006
    Bradford, yeh baby
    Yeh i was hoping the case wouldnt be the case
    Oct 2006
    water in oil!? Not from the water pump seals!
    Quote Originally Posted by Toomey
    thanks
    The water comes from the
    1)sealing between the engine crank halves.
    2)broken head
    3)cylinderhead gasket
    4)O-ring at the cylinderbottom
    NOT FROM THE WATER PUMP
    May 2007
    Florida
    Quote Originally Posted by Maxipower
    2)broken head
    Is that seal #8 between the motor oil and tranny oil the one that is commonly blowing causing the motor oil to fill the trans?
    Dec 2006
    North Yorkshire
    no that is behind the clutch in the oil pump.
    apriliaforum Member twinshocker's Avatar
    Apr 2007
    Bavaria
    When you have gear oil in the airbox, not motor oil it can be the waterpump seal (11) which was the case with my RXV
    Oli
