well wen i get to 8,000rpm the povervalve opens and the revs fly up to 11,000 as normal but it has stopped speeding me up its hard to explain the revs fly up but it wont go any faster and it does this in every gear any ideas what could be wrong?
That does sound very odd one! Could be clutch slip. From what you advised, I wouldn't really know unless I had a test ride.Originally Posted by jonesy_125
Have you taken the powervalve out the cylinder and given it a good clean + bit of 2 stroke oil on the blade then pop it back in. From what you was saying, it sounds like the clutch is on its way out.
Has it always done this since you had it? Whats the milage? when was the last top/bottom end rebuild?
Mods:
Race backend fairing
Racing side fairings
Differnt sticker kit
Double H sintered pads
Gold chain and 38t rear sprocket
Gold Bar ends
Next mod::Twin JL exhaust
its only done 8,000km so it aint had a rebuild its only started doing it the last 100km or so and i took the powervalve out and cleaned it and it made no difference and it had new clutch plates bout 300km ago
not changed the sprockets lately?
Adjust grub screw on the clutch casing.
Are you getting no power atall after 8k? Or just like its restricted. If its like its restricted and not giving you much power after that revs, it could be that your powervalve blade needs a good clean?
thats my guess
2004 RS125 fully de-restricted,
Mikata Kit
Carbon Fibre Yoke protector
Carbon Fibre heel plates.
34mm carburetor.
PiperX Conical
next -- JL
sorry misread there![]()
in my experience when a clutch is slipping the engine will revv alot more than usual! due to the fact its like pulling in the clutch slightly! think about it just for a second.
have you ever changed the gearbox oil?
jets?
Trevor
jets?
Trevor
whooops! posted it twice!
yea i changed the gearbox oil when i changed the clutch plates
I would def put it down to the plates slipping! adjust the clutch using the special tool that aprilia gave you. Full guidelines in the owners manual.
Mods:
Gold Bar ends
mine just started to do the same thing. but i have got a smalll gearbox leak so im fixng that today.and puttting in new oil and powervalve clean.il let you no how i get on with it later.
Originally Posted by MONKEYBOYY
cleaned filter carb powervalve and oil change bikes running mint again![]()
