Hey all, does anyone know how to cancel the "wrench" service light? Tuono ,07
thanks, Don
thanks, Don
with the key in turned to on but bike not running put the left hand switch in the "mode" position. Using the small square button under the flasher button on the left handle bar enter the service mode. Using that same button enter the code 13432 by pushing the button until the desired number comes up. To switch to the next space hold the button down until it switches. When you've entered the entire code hold it down and it will get you into the service menu. From here you will see the option to reset service indicator. Select that, it will ask you if you're sure, select yes and you're done.
For my money it doesn't get any better than when he sings, "When a man loves a woman". I celebrate his entire catalog.
