im after a complete RS50 engine. anyone got one for sale?
where are you located at?
EXCREW RIP 1/08/06
01 RS50/72cc MetraKit HM, MK cdi, Arrow CF, 21mm del phbg, uprated Clutches, Cf reeds, DiD chain, Galfer front and rear ss brake lines, Tinted Screen...
01 Rieju rs1-50 stock stock stock :thumbdown
Backup motor 04 AM6 motor, athens74, 24mm del, Doppler ER1 crank, Barnett Clutch, stock pipe
Plymouth, devon, UK
Matts selling a rx50 engine. Not sure if the ratio's are different. http://www.apriliaforum.com/forums/s...highlight=rx50
Is It Still Available?
ask him![]()
Yep, still available if you're after it![]()
Today when people talk of "living through hell", it usually means that their appeal against unfair dismissal has been delayed, or the builders next door have been very noisy for several weeks. For the millions of soldiers in the trenches of the First World War, their experiences of Hell on Earth were beyond anything those of us born into Britain's most blessed generation can possibly imagine.
you have a PM![]()
I may have a 2000 RS50 for sale it has 388 miles and has been apart since 2003 after someone tried to put a a big bore kit on it.
SpeedEng, are you selling your spare motor? I bought another RS50, but when I disassembled the thing (it wasnt running, didnt pay much) the whole bottom end was full of coolent (bad head gasket) and i'm worried i'll have to rebuild the crank.
Current Bikes
2002 Aprilia RS85 - 2005 KX85 motor, MyChron3+ guages, FMF SST pipe, AF1 Upper Triple, WoodCraft ClipOns, TCM Rear Sets,Bitubo Rear Shock, Bridgestone 125 slicks, 14/42 gearing, DID-NZ gold chain, race trim.
2000 Aprilia RS50 - Malossi MHR Replica Cylinder, 26mm Dell'Orto Carb, Metrakit SP Exhaust, Barnett Clutch, Pre-mix conversion, 13/43 Gearing
Past Bikes
2001 Aprilia Mille R - Arrow Titanium Slip-On, Evoluzione LP bracket & tail light integrator, carbon rear solo cover, carbon taillight surround, carbon chain guard
Am currently rebuilding am6 from two engines which I plan to sale. I live in bristol. The final engine will have a polini 80cc alloy big bore, Pm racing crankshaft, a racing clutch plates and springs, 15tooth front sproket.
Not sure if you wanted a stock engine or a fuly modded one.
The engine original was in my motorhispania but was set on fire and the only thing serived was the engine but the plasics melted off and the wires.
I brought a second engine which if from a rs50 which was siezed so am going to rebuild it with all my performance parts. Not enjoying rebuilding it for the second time.
Bike is dead, was set a light.
Motorhispania furia which had Polini 80cc kit with reeds and exhaust power boster, PMTuning race crankshaft,ront sprocket 15t, metrakit exhaust and racing clutch.
Now have a nsr125r (could'nt afford a rs125 lol)
i reckon you should go all out and buy the new tp 86cc kit, comes with crank and cylinder and bearings i think... but it would be so fun!
mine did that! crank was swimming in coolant, i tipped it out and dried it as best i could, left it in the sun for a bit, then rebuilt top end, worked fineOriginally Posted by RSr
Thanks for the info, its somewhat reassuring to hear somone else had this problem and didnt' have to replace the crank.Originally Posted by RiejuR51
Current Bikes
Past Bikes
wow you bought another rs.. where do you find these deals at?? hook me up..
but if you do still need it (motor) hit me up.
EXCREW RIP 1/08/06
