Page 2 of 2 FirstFirst 12
Results 16 to 28 of 28
Thread: pv questions,heres a pic of it,help needed
    apriliaforum expert jenko's Avatar
    Nuneaton UK
    that it goldy if u take the cable out of the blade and housing the housing will come of leave the blade/spring behind so u can get a better look at the blade
    apriliaforum prov-nov allzars125's Avatar
    Woking, Surrey
    This is the exact same thing that happened to me, it was stuck solid. What i did was to get a screwdriver in from above and lever it out. then when it moved a bit i would spray carb cleaner(wd40 will do) on the bit that i could see. then I would push it back in and try and lever it back out again, each time it would come out a bit more. Be careful thought when trying to lever it as it could bend if you don't keep it straight. It may seem as though it will never come out but eventually it will.
    apriliaforum expert GOLDY21's Avatar
    NORFOLK,UK
    cheers m8 here we go i have done it........
    is this as dirty as yours was?
    goldy
    Woking, Surrey
    yep although yours looks a bit more oily to me. Must have been hard work getting that bugger out. It will make a big difference once cleaned, a lot smooter and faster.
    Post Whore Craig's Avatar
    Guisborough
    That blade will have been sticking too...
    How many miles the bike done? that looks like its runig way to right or has been stuck for a long while or useless oils have been used.
    VAG Cars - www.vagcars.co.uk - North East VAG Owners Club
    apriliaforum expert ajak_79's Avatar
    somewhere in asia
    if the pv got stuck, some tip here. first warm up the engines, then rev ya bike bout 1-2 minutes, after that wait the engines cool down, lastly try to pull the pv again.
    cheers!
    NORFOLK,UK
    yo
    that was one hell of a bastard to get out!!!
    the blade now is half the size it was!
    the oil and residue was caked on,this must have been the 1st clean its ever had for sure
    the mileage m8 is 14507......i assume it km,lol
    but yeah the light has beaten me today so i will resume in the morning,so i guess this will have sorted my problems now guys?
    i.e boggy and slow dramatically b4 pv kicks in?
    i hope so,if nothing else i have found that there is bolts missing that shouldnt be......god only know why they are not there
    goldy
    apriliaforum Member Carnivor's Avatar
    Bristol
    talking of missing bolts!
    I just discovered that 2 on the left side are missing, so i moved the top one from the right side and put it into the bottom missing hole on the left, i dunno if its me but im sure the ride is alot smoother,
    '97 RS Extrema 125, Derestircted
    NORFOLK,UK
    so what happens if the pv stops working?
    will it just run/ride in restricted mode again?
    even though it has still got cdi mod
    goldy
    Bristol
    well... i aint got a cdi restriction, my bike is to old.,, but when my pv was stuck open all the time it was very grumpy upto 7.8k rpm then flew, it was hard to pull away, hardly any accelleration. i think this worse than being restricted.
    Nuneaton UK
    yeah with the pv fully open its a complete nigthmare doing hi starts
    u are a:asshole:
    how long these smilies been on for?
    apriliaforum Member Shady2004's Avatar
    Plymouth UK
    Hey...
    I got same model as Canivor But My pv Blade Is Knackered if I was 2 take the blade out & do evreything back up wud I have constant power flow or wud it run like cr@p ?
    Bristol
    trust me its crap until 8k rpm, its almost like flooding the engine.
  1. Fitting old fairings on new shape rs125, need pic!?
    By stu_rs in forum RS125 Euro-archive
    Last Post: 05-13-2004, 11:07 AM
  2. pic to large
    By 02moab in forum Aprilia Owner's Pictures, Videos, and Sounds
    Last Post: 05-12-2004, 05:06 PM
  3. Got a pic of carbon front fender? (Craig?)
    By random008 in forum RS125 Euro-archive
    Last Post: 03-14-2004, 05:30 AM
  4. RAVE unit pic needed
    By Sam in forum RS125 Euro-archive
    Last Post: 12-10-2003, 10:19 AM
  5. HERE WE GO JONNY.......carbon bits,lol + pic of me bike
    By GOLDY21 in forum RS125 Euro-archive
    Last Post: 10-12-2003, 09:10 AM
