Results 1 to 10 of 10
Thread: OEM Parts Diagram Demonstration '01-'02 Mille, Mille-R
    Racing SERVICE Competition Steve / AF1 Racing's Avatar
    New Braunfels, Texas USA
    Photos of 2001-2002 Mille, Mille-R, Models with color scheme names and abbreviations:
    AF1 Racing, inc / ApriliaForum.com
    699 W San Antonio St
    New Braunfels, TX 78130
    direct:830-626-3966 fax:830-626-3969
    Currently:
    '97 RS125 Two Stroke
    Previously:
    '00.5 Mille & '97 RS250.
    Photos of 2001-2002 Mille, Mille-R Models with color scheme names and abbreviations: (continued)
    Currently:
    Previously:
    The following is a step by step demonstration on how to identify an OEM part as seen on AF1 Racing's Online Shop.
    For this walkthrough we will assume that you are looking for a Front Fairing for an '03 Tuono.
    -First, identify the name of your color scheme by using the photos above.
    -Locate the page which contains the part you are looking for, In this case it will be the "2002-2005 RSV Tuono Front Body - Front Fairing" section found in the "2002-2005 RSV Tuono" directory.
    -locate part in the diagram (red circle in diagram below)
    Currently:
    Previously:
    -The part we are interested in is numbered "1" in the diagram. The corresponding number on the table is indicated with a red circle below.
    Currently:
    Previously:
    -Now consult the photos at the beginning of this thread to identify the color scheme of your Tuono.
    For this example we will say that we have the 2003 Tulip Red Tuono. Tulip Red is abbreviated as "t.red" in the table.
    Currently:
    Previously:
    The left portion of the "Version" column includes a note about the trim level of the part in question.
    Here "ST" means Standard models.
    -and-
    "RG" or "RF" means Factory or Racing models.
    When special part data like this applies, you will see a third table beneath the parts frames that decodes the meaning of the abbreviations that are seen.
    Currently:
    Previously:
    -The column labeled "Code" contains the part number.
    Currently:
    Previously:
    -The column labeled "Q.ty" indicates the quantity that will be needed to complete the application.
    For instance, the windscreen is held on with six pins, so a "Q.ty" of six is shown in this column.
    Currently:
    Previously:
    The part number is AP8168226.
    You can now submit a parts request to AF1 Racing.
    Currently:
    Previously:
    Important Note:
    In the vast majority of situations, Aprilia does not sell parts "kits." Aprilia parts are typically sold each. In very rare situations some Aprilia parts are sold "complete" meaning that all necessary parts for installation are included. This applies primarily to Accessory parts.
    In general, assume that All Aprilia parts are sold each, unless the product description specifically says "complete."
    Currently:
    Previously:
