Results 1 to 13 of 13
Thread: Question?
    Northern England
    Question Question?
    WTF is the little switch on the clutch lever pivot for?
    apriliaforum expert Davenet's Avatar
    Nashua, NH
    So you can start the bike in gear, with the kickstand up & clutch pulled in. Otherwise the bike would have to be in neutral to start, even if you stalled in traffic during a launch.
    Hopefully we are talking about the same switch...
    2000 RSV -All of the normal stuff
    2001 XR400r - Ice/Dirt Whore
    "DUDE, don't worry. We can fix it. My dad's a television repair man... he's got an awesome set of tools..."
    “If it’s sympathy you’re looking for, it’s in the dictionary between shit & syphilis. Pick one.”
    Stated by Al Tucker to ill equipped riders on a dual sport ride.
    Northern England
    Thumbs up Thanks
    Thanks for that Dave.
    apriliaforum expert stinky's Avatar
    Somewhere in the 626
    Does this actually work for you guys? My bike won't start in gear, even with the kickstand up and clutch pulled in.
    Northern England
    Yea, it works for me. I stalled the motor quite regular when I first got it and so used it a few times (without realising of course!).
    The switch arrangement looks quite delicate to me though, a fine sprung steel 'finger' which actuates the button switch.
    Maybe yours needs setting up stinky?
    apriliaforum Junkie Italibikefreak's Avatar
    NY
    Huh
    Mine starts up all the time with kickstand up and in gear with clutch pulled in. I wonder why yours doesn't start.
    Could be it needs a bit of adjustment. I've done a couple of quick hunts for neutral already.
    I'll take a close look at it today and see if I can get it functioning properly or if I'll need a trip to the deelah.
    Found the metal tab that the pin on the clutch lever pulls in to actuate the plunger on the switch was a little off. 2 seconds to move it where it's supposed to be and it's sorted. Starts fine in gear with the cluch in now.
    Pac NW
    I'm going to have to find this switch then cause finding neutral most of the time is a f@#$ing pain in the A$$!!!! Can anyone take a digi pic to show what it is?
    Working on it, Dvus....
    Here you go. When the clutch lever is pulled in, the Pin on the clutch handle makes contact with the Metal tab, which pushes in the Plunger of the switch.
    Another pic. Sorry about the angle and fuzziness - the tab is a thin rectangular piece of metal, and as MixR said, it's quite delicate.
    Pac NW
    thanks I looked at it and the rectangular tab was setup on mine. Just noticed it and Tried it out and woo hoo. It works all this time i was trying to find neutral.
  1. Re-using hose clips / Tank/pump question
    By Kiwi_M5 in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 10-09-2011, 08:05 AM
  2. Slip-on install question
    By RedFive in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 09-16-2005, 11:18 PM
  3. PC III question for Clarkie ...
    By Pierre in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 09-12-2005, 04:39 PM
  4. Another Newbie Question
    By skrump in forum General Motorcycle Talk
    Last Post: 07-15-2004, 01:32 AM
  5. Question about "wind noise": survey
    By XPADREX in forum ETV1000 CapoNord (all years)
    Last Post: 04-26-2004, 04:42 AM
