Results 1 to 5 of 5
Thread: BT-20s - What pressures do you use?
    apriliaforum expert cmcnamee's Avatar
    San Antonio, TX
    I recently installed some Bridgestone BT20s on my Fut. So far I've really enjoyed them, but I feel like the stock air pressure of 36.5 front and 40 rear are not quite right. Like the tires are too hard.
    So...... What pressures do y'all run in your BT20s? Keep in mind that I primarily do commuting.
    Carl
    Connecticut
    I run 34 frt & 38 rr in just about all my road bikes.
    John B.
    Dec 2003
    FOB Airborne, Afghanistan
    Quote Originally Posted by cmcnamee
    Carl
    The 020's will feel hard because they do have a stiff carcass(sp?).
    02 Aprilia Futura
    San Antonio, TX
    Quote Originally Posted by woodman
    I had wondered about that. Compared to the Z6's I've been using, the BT20s seemed a bit stiffer when I installed them. Guess I'll play with the pressure and suspension to get things back where I like them.
    Thanks everyone!
    Carl
    Brum
    when I put a Z6 rear on I jacked up the preload a few notches to stop the rear wallowing around, with the 020s I had to soften the suspension off again to save my spine. Both tyres were 36/41 front to rear.
