Results 1 to 15 of 16
Thread: Aprilia Clutch Push Rod Oil Seal For V990's
    Dec 2006
    "Help" Replace Clutch Push Rod Oil Seal For V990's
    Hello
    I have a RSV 2004 and the seal of the clutch push rod is leaking.
    Can any one please tell me how to replace the seal.
    Thank you
    Dec 2006
    Hello again
    Does anyone have a clue how to change the clutch push rod seal ??????????
    Please Some Help
    Thank you all and a happy new year
    Westminster, CA - USA
    Replacing that seal is fairly simple but can be tricky.
    Since there is no way to get to the back side to drive it out, you have to use a sharp punch to poke a hole in the seal and pry it out.
    The problem is that if you do it wrong, you could damage the housing and the new seal will leak even worse.
    apriliaforum expert Dr. Thrillride's Avatar
    Apr 2004
    Vancouver, BC
    Have you done anything to start the process? Do you have the new part yet?
    Take off the clutch slave (not shown in your diagram), don't mess with the cylinder. Take off the spacer (shown as #26) and take note of the rubber seal on the clutch push rod (neither shown in the diagram). Take off the sprocket cover (not shown) and plate (#25).
    From there on, I have no idea - besides get a screwdriver, pry the fricken thing out, and put the new one in.
    No seriously, no-one's helping because not many have done this, including myself. My best advice is to take it to the dealer.
    Quote Originally Posted by Nitz_Tuga
    Hello again
    Please Some Help
    Apr 2004
    Vancouver, BC
    There you go, Amauri to the rescue...
    Although it is a bit more work, the best approach for replacing the seal is to remove the clutch push rod after removing the slave cylinder. To do this you must remove the outer clutch cover and then remove the pressure plate and lastly pull the push rod out. With the push rod removed it is much easier to remove and replace the seal and you are less likely to damage the case or push rod. If you plan to attempt this your self you should get yourself a workshop manual which has a detailed procedure for disassembling the clutch pressure plate and all the necessary torque specs.
    Dec 2006
    Thank you all for the help i will try to do it.
    I will tell you the result.
    Jun 2004
    Annapolis, MD
    I had to replace one of the buggers on a 93 ZX-7 once. However this one was removed from the inside of the plate/cover. Which made the plate/cover had to come off. Well to get that off, I had to drop the engine. There were two screws that could not be accessed due to the frame being in the way. All that work to replace a 3 dollar seal. While I was at it I replaced the drive shaft seal too.
    So, this one on the RSV should real easy....but can you actually get the part? Thats what would amaze me. I doubt dealers would caarry that in stock. but being a rotax it might be a common seal for their other motors...
    apriliaforum expert theknurl's Avatar
    Mar 2007
    Palos Verdes Est. SoCal
    Thumbs up seal puller
    this is what you need.....
    a Lisle # 58430
    ebay.....
    Noel-theknurl
    The Forum Curmudgeon
    I'm not PC either
    email/PayPal theknurl@yahoo.com
    Skype theknurl
    ph. 310-414-7247 PST, GMT -8
    Mar 2005
    Sweden
    Quote Originally Posted by theknurl View Post
    a Lisle # 58430
    ebay.....
    theknurl what did you drink yesterday?, i want one! , 9 Years bump
    Jan 2013
    U.K.
    excellent timing...I have this issue ATM ..!
    Oct 2004
    San Marcos, California, USA
    Thread revival!
    Any recent experience on this deal? Assume it's best to have oil drained or does it not matter?
    Figured a tool like this should work ok. Yeah?
    Nov 2017
    Brocks UK
    They look very 'dental' to me.
    If your dentist uses those you are in big trouble.
    No need to drain the oil, SD. I think you will need something a bit stronger that those pics to remove the seal. Look at theknurl's link.
