ive got 2 RS50's both have 5 gears but most mi m8s have 6 gears wots the gear ratio difference?? sum1 help me
strap up an hold on tight cos i ride hard an fast
i guess that you have the older type with the am5, and ur mate with a am6 (if it isnt the brand new model)
i spose havning an extra gear would give slightly better acceloration and mab a bit more top speed.
is ur mate much faster than u?
Oli
well i got a 2002 RS50 GP model and a 2003 RS50 both wiv 5 gears but mi GP model can beat mi m8s 6 gears even tho they both stock soo i dno wots goin on an how its wrks write bk sum1 and explain
2002/3 should have 6 gears,
i think it is only the pre 97/98? bikes that use the am5
Oli
99 onwards have 6 gears. You should have 6 on both of yours if you have two 2000+ models.
Try looking at your gearbox, maybe its a little screwed. Either that or push with your foot harder.
R.I.P Mark Limpus
or he isnt going down one just going straigh up????
my 98 rossi rep had 6 gears so the 98 had an am6 aswell
Check your gears again mate. You definitely have 6.
You're not going straight up are you like Adam said?![]()
R.I.P Mark Limpus
no i aint goin straight up into 2nd ive tried in 5th shiftin higher but it jt revs no 6th gear change how weird is tht tho
seems to odd to be true, that they are both like that. They had any work done to the engine in the past?
the GP 1 had a engine rebuild at 8000km that was the piston they had to chage the guy i brought it off sed an the 2003 has just had the piston change cos the twat i brought if off used it for racing without tellin me wen i brought it so the piston went and it was all racing spec stuff so ive had it all put bk to normal by a official aprilia dealer i rly dnp wot to make of this 5 gears thing its got me stumpd an i fink its got u lot stumped aswell
your engine will have AM6 stamped on it, i believe its just under the sprocket shaft, take a look
is there neway i can c it wivout takin fairings off ??
a big torch and an allen keyOriginally Posted by jackeo_RS50
