Page 20 of 20 FirstFirst ... 10181920
Results 286 to 293 of 293
Thread: Futura and Caponord dash repair
  1. #286
    May 2009
    Singaore
    Glad to inform that I managed to solve the problem by using alcohol to clean the contact points. Hooray
  2. #287
    May 2009
    Singaore
    Quote Originally Posted by stl67 View Post
    My Right side LCD display is very weak. So I stripped it and see if there is anything I can replace. Nothing much I know how to do. So I assemble back and now the Odometer display is gone. Have I damage anything?Attachment 345407.
    Back to my Dashboard again. Anyone knows how to repair the fading display on the right side. I was told this is common problem because of sunlight.
  3. #288
    Nov 2017
    Baton Rouge, Louisiana USA
    Greetings all I am a new Proud ETV 1000 caponord owner, with that being said I am having a dash issue That goes away when the bike warms up or sits in the sun all gauges work. Would be appropriate first Direction be to try the zener diode jumper? Or is there another known weak link that warms up and connects? While under power if I jumper from one side of the panel to the other with a clip-on connection it does not resolve the issue however if I run a jumper from power to pin 17/18 bridge on IC chip all lights light up. Thank you for any and all insight. Nito
  4. #289
    apriliaforum expert rblue02's Avatar
    Blueridge GA, USA
    NitoYo, getting the dash out is tedious and the dash buttons or dash plastic
    or dial pointers can get damaged.
    Seems it might be prudent to do both the capacitor changes & via/feedthru fix.
    Some even reflowed most of the solder joints. Be careful not to overheat and lift solder pads.
    Good luck.
    '02 Futura, Blue
    93k miles and all is well.
  5. #290
    Oct 2017
    Sydney
    Hi Meanstrk,
    You dont have a high res photo of the left hand side of the PCB at all? im trying to find the SMD resistor value for the far top left resistor in the red circle below. Mine fell off through age I assume and I need to replace. (2001 ETV 1000)
    An assistance would be greatly appreciated.
    many thanks
Name:	pcb resistor.jpg
  6. #291
    Nov 2017
    I have jumped the zener diode to the back of the capacitor and changed the 16v capacitor. I also just noticed three scorch marks (see pics) in the board traces, which I guess I need to repair. I can get LED's to lightup if I jump from zener to midway up right side of ic chip. But other wise, dash stays dead until things heat up quite a bit. I am game trying a few more things with some direction, but am unsure which way to go at this point.
    Is there anyone in the US that works on these boards? I believe Ron has retired. I can send it to Moto-Abruzzo, but that may take a great deal of time.
    Thanks! Nito! Yo.Click image for larger version.
ID:	354729Click image for larger version.
ID:	354730Click image for larger version.
  7. #292
    Sep 2004
    Sweden, Linköping
    In the moto-abruzzo capo home page, in the archive, in november 2017, he has an article about the most common part that fails in the dashboard.
    Mods: Modified Öhlins fork from mille R, EBC brake discs, HEL front brakelines, Carbon RS 250 front fender, Wiring mod for charging. Engine related:05 map, Iridium plugs, tuneboy, derestriced intake, old mille airboot, staintunes exhaust. Lambda bung hardbrazed in the "breadbox". Öhlins mille R rear shock with 110N/mm spring and the integrated hydraulic preload adjuster. LED Voltmeter installed inside the dash for monitoring charging. Duc 999 radial m/c for brake and clutch. EBC 320mm brake discs
    CBR 600 -07 MOSFET R&R FH008EE providing stable 14.4 - 14.5 V (with my wiring mod). Daytona heated grips with mccoi pwm controller and automatic chain oiler
  8. #293
    Nov 2017
    Thanks! I did already change that capacitor and also jumped the zenor diode to the back side of the large capacitor.
