Results 1 to 6 of 6
Thread: Flywheel nut /// Big End bearing
    apriliaforum Junkie aprilakias's Avatar
    Mar 2005
    I wonder should i undo the M12 X1 nut anticlockwise as any other nut or clockwise ?
    And does anybody know which is the code number of the big end bearing ?
    I am doing a bottom end rebuild so i am sure will come back with a few more questions
    Wolverhampton west mids
    Normal way Rh thread undo anti clock wise
    You can not buy just a big end bearing only full con rod kit
    ALL PARTS STOCKED FOR THE APRILIA RS125
    Jim Loamas Pipes Jolly Moto Pipes Piston kits Prox Vertex Mitaka Wiseco Genuine, Gasket Sets, Main bearings, Crank seals, Con Rod Kits. , Chain and Sprockets, Spark Plugs, Brake Pads, Levers, Screens, Exhausts, Mirrors
    SERVICES
    Full Or Part Engine Builds, Cylinder Re-Conditioning, Crankshaft Re-Builds, Thread Repairs,
    apriliaforum expert Gman2005's Avatar
    Sep 2005
    Leciester
    bummer lol, so you cant get your bearings changed then? Why is that Mr Engineer type person
    R.I.P Spike
    The smell of two stroke smoke, ummmmm
    I'v almost got my knee down
    Aprilia Yorkshire motorcycle spares and accessories
    Peter Knight
    PJ engineering
    Tj Tunning
    Quote Originally Posted by Stanley_Aprilia
    It needs to be like when a man makes love to a woman, speed and endurance are the key to a wet minge, 2 pumps and a squirt aint good enough.
    RockOil Fully Synthesis 2 Injector
    May the force be with you
    Aprilia RS125
    apriliaforum expert AndyS_RS's Avatar
    Aug 2006
    www.tjtuning.co.uk/forums
    Big end bearing only comes with a conrod kit because they wear as one. Along with the crank pin.
    I have a feeling that he ment main bearing though?
    Quote Originally Posted by AndyS_RS
    Bang on there are 3 bearing surfaces
    1Crank pin
    2Big end bearing
    3Conrod
    All 3 wear at the same time so all 3 need to be changed, That is why they only sell a full kit
    SERVICES
    Sep 2005
    Leciester
    Got ya thanks boys :>
    R.I.P Spike
    Peter Knight
    PJ engineering
    Tj Tunning
    Aprilia RS125
