New bike to be released
STR 650 CRC
ENGINE: single cylinder 4 stroke
GEARS: 6 STARTING: electric with automatic decompressor
COOLING: by liquid
IGNITION: C.D.I. electronic, with adjustable advance
CARBURETOR: Kehin MX 41, dia 41
FRONT BRAKE: 320mm
REAR BRAKE: 220 mm
FRONT FORK : Upside down hydraulic telescopic fork, dia 50mm
REAR SUSPENSION: Progressive, with patented eccentric system for the continuous adjustment of the set-up, single shock absorber with external spring preload, rebound and compression damping.
FRONT/REAR TYRES: 120/70-17 160/60-17
KERB WEIGHT: 132 Kg
WHEELBASE: 1437,3mm
MIN. GROUND CLEARANCE: 333mm
SEDDLE HEIGHT: 900mm
FUEL TANK CAPACITY: 13 lt
